RPM Air Gap with Q Jet?
Hey guys, ive done a bunch of research and all ive found is conflicting opinions.
My question is this: can i fit the edelbrock performer rpm air gap with 3/4" adapter and qjet carb under the stock 79 hood with a drop base air cleaner?
If so, can you reccomend me a drop base air cleaner that will give me enough clearance?
As the hoods of C3's vary from year to year I suggest you start by putting some modeling clay on the top of your air cleaner then close and reopen the hood so you can measure the amount of clearance you have now.
Then measure the height of your present intake manifold and see how it compares to the height of an Air Gap. Draw a side view picture of what you have now and what you will have with the parts you want and determine if the parts will fit under your hood. All of the parts have height specifications so plug those specifications into your pictures and see how they come out.
I have an RPM airgap, 3/4 inch high adapter,Qjet and drop base air cleaner with 3 inch element under the hood of my 77. I have the back of the hood raised with washers and I have a flat nut on the lid because a wing nut will hit. It's that close. I also have solid motor mounts because there is no room for engine movement. But it all works great.
And if it's not going to fit without modifying the hood, do you think I will lose much performance by going with the performer RPM instead of the performer RPM airgap? I'd prefer the Airgap, but the plain old Performer RPM is available with a Q jet pattern so no adapter would be needed.
unless you have done something else to the engine that requires a 6,500 rpm intake go with the performer or performer air gap
I'd like to run the RPM airgap if at all possible, but if I can't, I'll run the performer RPM.
I'm getting a little confused by the names you are calling the manifolds. There is the Performer, the Perfomer Air Gap, the Performer RPM, and the RPM Air Gap. The last two are the exact same height and are the 6,500 RPM manifolds and are square bore. The first two are the spread bore pattern with a 5,500 RPM figure and roughly 1" shorter.
http://www.edelbrock.com/automotive/mc/manifolds/chevy/
Dr. Detroit
Received 3,891 Likes
Just run the 7104 Performer RPM Q-Jet manifold.....
Unless you have to have the looks of the "Air Gap" because it gives absolutely zero benefit at all.
All intakes heat soak until they are all even in temperature across the whole part...Air gap or not.....
Hot Rod and Super Chevy proved that the runners between the two show zero advantage as well.
Not only that....but a Q-Jet to Holley spacer is a horrible mismatch in a four hole design.....an open one is not that bad....but divided plenum dual plane manifolds do not like open spacers......
http://www.summitracing.com/parts/EDL-7104/
Jebby
Jebby
BV85 (04-27-2016)
Received 3,043 Likes
St. Jude Donor '05
Planning for the future is good and all but put what works good on there today so you can really enjoy it. Most need less intake than they think they do
Yeah I realize that both of the RPM intakes are the same height, however since I"m running the Qjet I would need a carb adapter to run the RPM Air Gap, which would require another 3/4" of hood space. The Performer RPM is available with a spreadbore pattern so I wouldn't need a carb adapter. I would prefer to run the Air Gap, but if I can't fit it under my hood (due to the required adapter with my carb) then I'll just run the Performer RPM.
Jebby
Jebby
And thanks for bringing that to my attention, I didn't think about how the spacer could affect the performance.
Sounds like I might as well just go with the 7104 and a drop base air cleaner.
Yikes! Do you have a picture of the hood fitment now that it's shimmed with washers? Curious how much it sticks up.
BTW - my adapter is the "open" type
Jebby
Jebby
Jebby
Jebby
Thanks for all the input guys. I think im gonna go with the performer RPM since all it should require is a drop base air cleaner, and it should perform almost the same as the air gap.
Also, IMO you'd be better off NOT running an adapter between the carb and intake. Anything you "may" gain from the airgap design would most likely be lost in using an adapter.
You will get the same affect as the RPM Airgap if you use the Performer RPM Q-Jet and install intake gaskets that block off the exhaust crossover and install a lifter valley shield. The runners aren't kept isolated, but you will keep the exhaust heat and hot oil off of the bottom of the intake.
Yeah I'm thinking the same on the adapter. Thanks!
Where would I find a gasket that block off the exhaust crossover? I'm most likely ordering from Summit, so if they sell one, could you point me in that direction? And I'll probably take your advice on the lifter valley shield!
Mr. Gasket 101B - Intake Manifold Gasket Sets
Performance Material
1955-91 Chevy 262-400 V8
Thickness: .060''
Rectangular Port Size: 1.25'' X 2.00''
http://www.jegs.com/i/Mr.+Gasket/720/101B/10002/-1
Good luck... GUSTO
I use Play Dough..
