Restoring alternator
How can I make my alternator look like new again? It is stained, and I've tried some aluminum polish, but that didn't do much. This winter I am prepared to disassemble and rebuild it. How can I recondition the casing?
Re: Restoring alternator (Turbo-Jet)
I have used "Cast Blast" paint on mine. There was a thread about it awhile back, so I tried it. Looks pretty good, maybe a little darker then original. Seems to be holding up OK
Tell you what I did. Took the alternator off the car and went over the whole thing including the fins and pulley with a medium grade wire wheel in a drill press. It polishes up all the metal and removes all corression. Then wiped it down with a wax and it looks great 2 years later.
1 Post
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Re: Restoring alternator (Bob Demmel)
I actually did this a few weeks ago,i was very curious how the alternator looked inside,so i picked it apart :D .I took the alternator house and put it in a mxture of Degreaser and citrous cleaner,let it soak for a while and it worked really well...
You see,when i`m bored,i always find something to pick apart and investigate,even if it works :smash: :smash: :lol:
Re: Restoring alternator (Twinnie)
Brother-in-law did it on his 73 Nova, looks new....
S.O.S pads with cleaner in the pads (blueish green kind) little water and a dry towel. Dip s.o.s pad in water.... scrub then wipe clean, looks brand new!
Hope this helps.
Mike :seeya
Hope this helps.
Mike :seeya
