Spring cutting/lowering front end
#41
I just checked my driver's side, 27 1/4" ground to fender, I could get 2 fingers in the gap which translated to about 1.5".
Again, untrimmed 550s and 27.1" tires. One thing that I forgot about is that I'm running bilstein sport shocks in the front - I know some shocks let the suspension sit a little lower than others.
#42
C3 of Year Finalist (track prepared) 2019
There is absolutely nothing wrong with cutting a spring if it is done properly and is not a spring with flat ends. In fact, as you are increasing the spring rate, a cut factory gymkhana spring will likely handle better than an aftermarket one at the same ride height, though it will of course ride stiffer. It also allows you to creep up on the desired height/geometry, rather than just accepting whatever comes off the shelf.
#43
Are you talking the factory 550 gymkhana springs or the aftermarket ones? Aftermarket ones are lower.
If I was really trying to finely tailor ride height and spring weight, I wouldn't be bothering w/ the stock suspension, FWIW.
#45
Nam Labrat
Received 4,154 Likes
If the car sits lower than you prefer after cutting the full coil you can buy a hard rubber spacer that rest in the lower control arm pocket/the coil spring sits on the spacer and increases the gap above the tire.....I added 1/2" rubber spacers under my coil springs.
Before:
After: After this pic was taken I lowered the rear the same anount
#46
I don't believe that to has to be multiples of a coil, but that's my opinion and it's obvious that others disagree. I cut off half a coil first, sat fine, spring sat happily in the seat, no noise or other abnormalities. I then cut another half coil as I was still above VIP specs. But to each their own.
#47
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
I don't see a problem cutting any amount desired off a coil but I've never done it. In order for the coil to rotate, the top coil would need to rotate out its pocket, no? And I doubt the spring can unwind or wind in on itself. Or, maybe you could drill a hole in the lower CA and use the head of a bolt as a stop for the end of the bottom coil if there was a concern of the spring rotating.
#48
My car sat high like that also. i have alum heads, accessories, and radiator. I cut 1 coil it only dropped an inch, i took them back out heated the coil I cut to bend and shape to match factory end. When reinstalled this dropped my car to 25.5in. I did this going in know it could ruin my springs and I may have to replace them, plan was to do semi coil overs if they are ruined.
#49
Royal Canadian Navy
I've had my car out and put a few miles on her and rechecked ride height. It's still 27-1/4" on the left side but the right dropped a 1/4" to 27-1/2". I'm happy with that.
#50
Nam Labrat
