Vintage Air
Vintage Air
My son has a 74. It originally had a/c in it. When he replaced the engine the a/c unit was removed. He is looking into a unit from Vintage Air. The guy who put the engine in told him not to replace the ac unit telling him that it could damage the engine.
The engine is a jegs 355cid.
Any thoughts?
Any thoughts?
I don't see how replacing the AC compressor would damage the engine, I run a non-factory compressor on my 377. Lots of people run the vintage air unit, I hear good things.
I call B.S. on that one.
Thanks. The guy got him worried, so I figured I would double check it.
If I remember correctly... They changed radiators to a smaller one since the new engine is bigger and they were afraid of heat and other issues.
Or do what I did and spring for a Dewitts fan, and call it a day
ronkh57 (05-12-2016)
Thank you
St. Jude Donor '09
1974 vintage air
Any thoughts?
Any thoughts?
The only possible reason I can see for worrying about an AC system with a hi po engine, is the belts. Hi revving engines tend to throw belts, especially on an AC compressor, since compressors don't come with deep groove pulleys.
You're only going to throw a belt at high RPM, and if you do start throwing belts, you can always convert to a serpentine belt.
Which engine is it? Jegs sells 5 different 355's that range from 310hp to 385 hp. I think you could run AC on any of those.
