Headlight vacumm help
Old 05-12-2016, 11:14 PM
lancer013
lancer013's Avatar
Default Headlight vacumm help
I have a 82 corvette cross fire injection just got it running descent i pretty sure my booster leaks but i was trying to test vacumm to headlight im getting vacumm to the 2 small black things and there vacumm to the bigger canister what would be my next step
Old 05-13-2016, 07:14 AM
newbie2vette
newbie2vette's Avatar
I gather that the car sat for a while, meaning the problem could be multiple vacuum components for the heads light. I recomment looking into electric conversion. for less than 200 you can eliminate the vacuum all together. PM me.
Old 05-13-2016, 07:39 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
Are your headlights raising and lowering?
Old 05-13-2016, 09:40 AM
tyancey00
tyancey00's Avatar
go to Wilcox and down load their head light drawing. it will help with all of your questions.
Old 05-13-2016, 12:06 PM
lancer013
lancer013's Avatar
Light wont come up at all can i use a conpressor and try to push air into canister would that make healight go up
Old 05-13-2016, 03:26 PM
Peterbuilt
Peterbuilt's Avatar
Received 1,244 Likes on 965 Posts
Default Hi and welcome again.
No! Most of the time if the headlights won't come up it's because the 'seal' (grommet) is leaking and needs to be replaced.
Here's another trouble shooting guide.
http://www.corvette-101.com/vacuum.htm#actuator
Old 05-15-2016, 09:29 PM
lancer013
lancer013's Avatar
Ok so i played around with lights when i blow air in red hose lights will come up and when i blow in green lights witll go down there a very faith vacuum pressue comin from relays so do u thibk seitch or do i need more vaccum
To Headlight vacumm help
Quick Reply: Headlight vacumm help
