Please recommend an intake for my 383
Guys, building a 383, cam specs are: Bullet cam, .588 lift intake/exh, dur 227/232 @.050, LSA 111, will be 1.075 smaller base circle for clearance on 5.7 rods. Have AFR 195 Eliminator straight plug heads. I need a recommendation for an intake..looks like I will have clearance issues with the stock hood on my 79..suggestions? Plan on running a Holley 670 cfm.
My 383 motor has a team G single plane and a 1/2 inch 4 hole wood spacer and a dropped base K&N with a 2 X14 with filter lid
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
I run a Team G on my 355 with a retro HR .560" lift I/E and same duration as yours. Also a 650 Holley Street HP carb with a 14"x4" air cleaner on a 1-3/4" drop base filter under a stock hood. Car runs fine with the single plane and I'm willing to bet as good as or better than the ever popular RPM air gap. I doubt you will go wrong with the Team G for the street or track.
St. Jude Donor '11-'12-'13,'19-'20
I am running a Dart dual plane airgap style intake on my 383 with a holley 750DP and LT-1 Air Cleaner w 3" element and it all fits just fine in the 73. ...and beautiful smooth cruise and throttle response!
Tibbs (05-21-2016)
I thought you were going with this? Howards retro roller 110885-08 278/278 dur; .525/.525 lift; 108 LSA If you want more lift 1.6 rockers will get you what you need.
I was told that I needed a small base circle camshaft and that that Howards was not small base circle, so I consulted w/Mark from Bullet cams at the recommendation of my short block builder. BTW, I will install the Comp Ultra Rockers you recommended but will be 1.6 ratio..thanks for your recommendations and expertise
Tibbs (05-21-2016)
My 383 was built for the drag strip years ago. Last year, I swapped out my sr for hr. Howard's cams(normal size) .560 lift, with 1.6 rockers. The hood has been for clearance. Running rpm air-gap at the moment.
Tibbs (05-21-2016)
Tibbs (05-21-2016)
Tibbs (05-21-2016)
Dr. Detroit
Received 3,892 Likes
I also run the 7530 Team G that is well massaged.....I recommend you do this or have it done.....
I would have left power on the table with the RPM,but not much...
If you get another hood....the Brodix HV1000 is a wicked mid to high RPM intake.....hard to beat once cleaned up.
Jebby
Jebby
Tibbs (05-21-2016)
Royal Canadian Navy
My cam will be custom ground and will be delivered in approx 3 weeks. What are the rpm numbers on your cam card? As i understand it, since I am planning on a lower rpm torque engine vs. high rpm, the single plane might not be the best intake for a lower rpm build. But hey, I m learning as I go..I really appreciate all the forum members input..gives a lot to ponder
