Courtesy lights stays on
Old 05-19-2016, 07:34 PM
cboyd
cboyd's Avatar
Default Courtesy lights stays on
Hey guys
Took the car for a ride tonight and the misses noticed that the interior lights remained on. I had this problem two years ago and replaced the delay timer and everything was fine until tonight. This happened after washing the car, maybe not related. It a '79 coupe, fully restored, except the wiring harness. Is there any way to bypass the delay timer, just to verify it is the problem before i order another one,
Thanks in advance
Clyde
Old 05-19-2016, 07:45 PM
billschroeder5842
Zen Vet Master Level VII
Support Corvetteforum!
billschroeder5842's Avatar
Received 1,140 Likes on 845 Posts
By pass the timer delay by disconnecting it.
Old 05-19-2016, 07:47 PM
silvvette
silvvette's Avatar
Yes, the courtesy unit is to the right of the glove box. Disconnect that and jump the 2 white wires. I also taped off the connector so that nothing would shortout.
Old 05-19-2016, 07:56 PM
cboyd
cboyd's Avatar
thanks guys
Old 05-20-2016, 05:22 PM
SwampeastMike
SwampeastMike's Avatar
It's sometimes easy to forget--are you certain that the dimmer dial for the IP lights isn't turned all the way left past the detent for manual courtesy light operation.
Simply removing the delay timer won't bypass it--the courtesy lights won't work at all. As said by silvvette, you have to run a jumper between the two white wires in its connector to get normal operation.
If the timer isn't the problem remember that the courtesy lights receive constant +12V. Both the door jamb switches and the headlamp switch supply ground to the circuit.
Most potable water is a poor conductor of electricity so it's very unlikely that car washing has anything to do with the problem. Cleaning the interior and inadvertently turning the headlamp switch all the way counter-clockwise however is rather likely
To Courtesy lights stays on
Quick Reply: Courtesy lights stays on
