What next for bolt on hp?
77 L82 4 speed. All smog stuff gone. Stock intake and QJ but open 14" air cleaner. 2.5" true duals with power stick mufflers.
Supposed to have non stock heads and cam but not sure any details. Doesn't sound like a wild cam. (As an aside, any way to find out details on things like this without taking things apart?) Anyway... Let's assume cam and heads are mild upgrades over stock.
Runs really strong after a tuneup, carb adjustment and timing advance.
Aesthetically I like the muscle car look of the open air cleaner, so chasing cold air over flow isn't a priority, but would be open to changing intake manifold.
The 2.5 "exhaust is bolted up to stock manifolds.
Basically I'm very happy with where it's at but want to maximize its ability to breathe in and out - IF I makes a difference you can feel. Will intake manifold and/or headers yield a noticeable difference you think?
I don't want to spend money on them if it takes a series of Dyno tests to see a 7 hp gain that you can't really feel.
Same question for an intake manifold.
Let's be optimistic and say between the current mods, I'm at a nice round number of 300hp. What do full (not shorty) headers and edlebrock performer intake get me up to? Ballpark?
ShipmanPhotos (05-23-2016)
The stock L-82 manifold is pretty good as is.
By giving up cold air for the intake you are giving up a significant amount of flow. The density of the air IS flow to the engine.
Say you have 600 cfm available to the engine. But the air density is only 90% (conservative) of that at sea level on a 60* day due to drawing in hot under hood air.
600 X .9 = 540cfm
The 600 CFM is still available just at a reduced density. So you just reduced your effective flow due to temperature, as far as the engine is concerned. You also reduce your HP potential and torque.
The air under the hood can reach 130* to 150* easily. If you are at seal level and it's 110* under your hood that is effectively like operating at 3500 feet.
You loose about 3% of density per 1000 feet. So in this case you have lost 10.5% of your air density.
Check out this chart for air density calcs.
http://www.ascentgroundschool.com/images/ct80802e/8.jpg
If aesthetics is a priority then to regain the loss due to air density it will cost some time and $$ to do it.
Better cam and heads come to mind as well as long tube headers. Increase your flow to the engine by 10% and you'll be back where you started. However it is hard to quantify the results without before and after testing, either on a dyno or in the 1/4 mile.
600 X .9 = 540cfm
Headers will help noticeably as will a roller cam with non stock heads. Which non stock heads to you have? A non L-82 flat tappet cam you have should help a bit, around 10-15 HP, over the L-82 cam assuming more lift. A .015 head gasket (Felpro 1094) with stock 8.9:1 pistons along with 64 CC heads would get you to 10:1 compression.
The L-82 intake is pretty good below 6,000 RPM so I would not mess with it. I reused my L-82 intake on my roller cammed, L-82 355, 10.2:1 compression with AFR aluminum 180 64 CC heads with new JE Forged Racing pistons in 2014 with my rebuild...engine screams.
Dr. Detroit
Received 3,892 Likes
A performer RPM Q-Jet manifold and a set of quality long tube headers will net you a solid 25 horse increase and a boatload of increased torque off idle.....
Jebby
Jebby
600 X .9 = 540cfm
600 X .9 = 540cfm
Now, as to your point about air density, I guess I do have a bit of a concern about what long tube headers will do to the under hood temp and will they potentially rob Peter to pay Paul by making the intake air a lot hotter?
It would help if you knew what heads and cam were in there. If you're running a <210* cam and a stock replacement head (IE any factory iron head other than Vortec), you won't be making enough power to justify going to a new manifold.
Headers and good exhaust are by far the best upgrades you can do to these cars. Start with headers.
You can pop off a valve cover to find the casting number for the heads. If you have Vortec heads, you'd have a different manifold anyway. Any pictures of the engine you can share? Casting number on the intake?
Are the current heads and intake aluminum or iron?
As far as the cam, you can get reasonably close with a degreeing wheel and a dial indicator. Figure out when the valves open and shut and how much. Divide by the rocker ratio of the rocker arms you have to figure out lobe lift and then you'll be able to figure out what cam you have to some degree.
You could also put a vacuum gauge on it and see what it reads at 800 RPM. That may give us an idea if the cam is anything even semi-performance like.
This is assuming you don't have any significant vacuum leaks though.
Also could measure the lift on the pushrod end of the rocker with a dial indicator to see what the lobe lift of the cam is.
ShipmanPhotos (05-24-2016)
Then if you are getting say 18" to 20" of vacuum you got a L-48 stockish cam.
18" to 16" and you slightly better than L-48 stock. This is probably where an L-82 stock cam would fall.
16" to 14" and you got better than stock cam.
14" or less and you're getting into a pretty good performance cam.
Less than 10" and you got something that has more higher RPM potential and performance.
You will need to know this in any case to get a vacuum can that is appropriate to the vacuum available.
The close proximity to the hood makes fiddling with the air cleaner very productive to maximize the horsepower. The shop that dyno'd my car squeezed like another 34 horsepower by changing the air flow/air cleaner setup on my engine. Granted it's a 496 big block, but I was stunned at the difference, and that was measured at the rear wheels.
A 3.73 gear would give you some really good seat of the pants performance!
You have "advanced" the ignition, but have you re-curved the distributor? Probably the simplest and least expensive way to add another 10% HP (or more) to your engine. Do a SEARCH for Lars paper on recurving the distributor. If you can't find it, send Lars an e-mail at V8FastCars@msn.com and ask him to forward you his latest version of this 'easy to do' process.
