Had to push her off to start?
I need some help from the experts out there.
I took my 75 4-speed out today for a ride in the nice GA. weather and to get a steak with my wife. Lucille (car's name) started perfectly and ran great to the steak house. Parked and went in and while we were waiting to be seated, I decided to move her to another parking place. She would turn over, but would not fire, went back in to eat (could not enjoy the steak while thinking about car) while hoping it was vapor lock. Finished the meal and tried to start her again, and same thing. Pushed her out of the parking spot and turned key to on position and put it in second and popped the clutch...started right up. Ran great on drive home and once in garage, she started right up every time I tried her.
It seems like there was no power to distributor, but now it's fine. It is hard to fix something went it ain't broke anymore....Thoughts.
Nam Labrat
Received 4,173 Likes
Rookie here/sounds like a loose connection: Connect a voltmeter to the positive terminal on the distributor wire connector(HEI)....then place it so you can easily see the meter....turn the ignition to the ON position.........start at the distributor an "wiggle" the plug/harness every few inches while watching to see if the voltage drops......work your way to the firewall where the wires enter the back of the fuse block. Then turn the ignition off for a while to letthe system "cool off". Then do the same wire wiggle test under the dash if necessary from the ignition switch to the fuse block.........also wiggle the fuses to see if the meter fluctuates.
Slightly move the key itself to see if the short is in the switch itself located lower on the steering column
Could the starter be getting too hot....?
On a side note...First trip I took my wife on in the '72 was to get a steak...It started after the meal, but went dead at a red light and wouldn't start back up....Came home on a rollback, dropped car in the driveway and yep it fired right back up. I'm in the North GA area as well.
Brian
Brian
Alwyn678 (05-23-2016)
possibly a bad key switch not giving power to the distributor in the "start" position, since you say it turned over fine. try using a remote starter switch on the starter with key in "run" and see if it starts, then try to duplicate the problem with the key in start. or just use a DVM to test all the connections...
This one got me a couple of times when I first got mine. I didn't push the clutch down far enough to engage the the safety switch
Update. I finally got her to not start after a good long drive in the 90+degree Georgia heat. Got home and let it set for about 15 minutes and tried to start, just turned over would not fire. Test power to HEI battery connection, had 12+ volts. Sprayed starter fluid in carb and started up. Engine compartment very warm. Engine running 190. Thoughts, vapor lock?
Sounds like it could be vapor lock. Next time look into the carb and move the throttle lever to see if gas squirts in, if no, then you are on the right track. Does it have the stock style fuel pump with the return line?
Received 3,043 Likes
St. Jude Donor '05
Wondering if your module or coil is starting to go
Update on starting issue.
I wanted to give an update on my starting issue. I realized that this started after I filled up my tank at a different gas station that I normally use. I have used the same station since I bought the car accept for that one time. I filled the tank at my usual station and then checked the float level on the carb, (had the carb rebuilt by a highly recommended local shop) the front float level was low, so adjusted it to the bottom of the float sight hole.
No problems since then, starts right up after long hot runs and short runs. Hopefully I am good now, we will see.
Update on not starting issue
After chasing this problem for about a year I think I have it solved. As mentioned in this post, there were times the car would not start with the key, motor would turn over but not start, it would start if pushed off.
Earlier this week the issue showed up again, but this time at home. I checked for spark and had no spark when turning the motor over. Went to Summit Racing a purchased HEI rebuild kit. Replaced distributor cover with new coil, new module and rotor button. Took the car out and noticed it seemed to have a little more perk and started every time.
Keeping my fingers crossed I have killed this gremlin that has been lurking
around for a year or so.
Will let you know.
Will let you know.
