K&N air
K&N air
Any thoughts on using K&N to improve airflow....any noticeable improvement in throttle response? I have an open paper filter now but would like to improve air flow.
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
I use them. They say they increase air flow but you probably won't feel it. What's nice about them is you can clean them, re-oil them and use them virtually forever.
I have tried a few air filters, including some homemade foam designs (on other cars from the Corvette), but always return to K&N.
I don't think you will experience a difference in performance that you can feel, unless your current filter is clogged and restrictive, in which case any replacement will be an improvement.
From a practical point of view, regardless of the make you choose, I would recommend as large a filter as you can fit. This provides the greatest surface area possible and keeps the velocity of the air at the point of passing through the filter to a minimum. This gives a lower restriction to flow which is a good thing.
I know this is (another) heated topic and I look forward to the arguments already, but for where I live (Scotland) we don't have excessive dustiness, in fact there is minimal airborne material apart from rain.
It seems to be that paper filters seem to be favored by those in dusty environments.
I like my K&N, the build quality is excellent and it works for me.
4" x 14" diameter on a drop base, Performer RPM intake and an L82 hood to clear it all
2018 C3 of Year Finalist
I would run a 14x3 paper if it would fit but since not, I have been running a smaller K&N. With the addition of a K&N filter top, motor gets plenty of air flow. No problems for years now.
highti=Blue Juice;1592278817]I have tried a few air filters, including some homemade foam designs (on other cars from the Corvette), but always return to K&N.
I don't think you will experience a difference in performance that you can feel, unless your current filter is clogged and restrictive, in which cashe any replacement will be an improvement.
[/QUOTE]
Hey blue juice is there anyway you can take a picture of the way you mounted the Gauges under your hood like to do something like that and how more hight did the l88 hood give you
[/QUOTE]
Hi Kevin,
Sorry about the slow reply, I was in the process of heading back offshore when I first posted.
I took a couple of additional photos before leaving, so here they are...
The car with the hood down and the gauges hidden
The Gauges are semi-temporary. I want them to be removable in the future without any signs being left that they were there, so I just used sticky squares and cable ties.
It worked out well though, and no-one has ever commented on them looking temporary.
The actual gauges are; An Air/Fuel meter with the sensor on the right-side collector, a manifold vacuum gauge to assist with carb tuning and a mechanical oil pressure gauge because I was having oil pressure issues and was (falsely) dubious of the factory electrical one.
The hood is an Ecklers L82. I have done nothing to it to at all. The gauges just fit in the space that was there.
I also have the black plastic cover for the windscreen trough. That's what the sticky squares adhere to.
From inside the car the gauges are easily visible (poor light in this photo)
I hope this helps.
I am 100% sure that a permanent installation would be easy to complete, but I am happy with my rough and ready set up, although I notice that I need to replace a sticky pad on the vacuum gauge
Cheers,
Douglas
I hope this helps.
Cheers,
Douglas
You won t feel any difference over paper element since paper will flow more than a stock motor can inhale .. I use K&N but I would not recommend them in very dusty areas. they do not filter as well
Hi Kevin,
I hope this helps.
Cheers,
Douglas
I hope this helps.
Cheers,
Douglas
Its just now worth it for me from what Ive see so far to use them anymore... they would be great for a track car but mine sees too much dust.
some of the of the many articles on the subject
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
http://www.bobistheoilguy.com/airfilter/airtest3.htm
http://www.jeepforum.com/forum/f9/k-...ml#post3886876
I agree too... I used a k&n in my 84 and after a few years the cotton gauze disintegrated (I did do normal recommended cleaning and reoiling) THEY DO NOT LAST FOREVER like people want to believe. The damage went unnoticed until I read an article posted on a truck forum I belong to... to make a long story short my 84 had less than 100k on it and burned a lot of oil when I sold it.. My truck which uses a paper element has 154k and still doesnt burn any oil... I am not saying the fact that the k&N broke down and allowed my dust through was the reason for sure for my engines demise but its very suspect after reading the articles where they tested them and found that even the new k&N filters allow more dust and dirt through than a paper element. its a tradeoff theres no magic solution that creates more airflow without allowing more dirt through from the same surface area.
I have had my K&N filter in the OEM housing on my 78 L-82 since 1985 and still do. It is in perfect shape.
I also have a K&N filter in the factory air cleaner housing on my 2008 Chrysler 300 since brand new, currently with 140,000 miles and had this same EXACT filter in my 2005 Chrysler 300 for 50,000 miles before that...Total mileage on this filter is 190,000 miles...motor does not burn an oz of oil. Filter is perfect.
And there is more....K&N filter in my 2001 Pontiac grand prix factory air cleaner assembly since day 1 when new, current mileage 190,000 miles...engine burns zero oil.
If your engine burns oil, it is probably not because of the K&N air filer....
Hmmmm...
I for one washed mine with the provided cleaner and rinsed them under my kitchen faucet before laying it out to dry and reoiling and it was apparently too much pressure because it didnt hold up. Maybe I did something wrong?
Plus they just dont work as well as a filter.. They allow more of everything through, air and dirt. if someone uses them in a dusty environment they would be a poor choice compared to paper. At least thats what all the actual testing seems to indicate.
Received 3,043 Likes
St. Jude Donor '05
Like many have run both went back to paper now never noticed an iota of difference
When they were cheap figured why not. Would just spray them down with hot water and Dawn, rinse out and air/blow dry. Very light oiling
On EFI cars I refuse to run them anymore, if oil gets past them and onto the MAF good luck.
St. Jude Donor '11-'12-'13,'19-'20
14x3 Paper here for the C3. New one every year! I put a KN dry filter in the C5 but no real reason cept they were on sale.
I dont think they add any measurable improvement.
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
Haters will hate and lovers will love. Oiled filters are meant for dusty areas that's why they are oiled to capture the finer dust particles. If there are MAF problems then they are over oiled. I've had a K&N filter in my '03 Ford Sportrac since near new. I only took it out a couple of times over 12 years to give it a shake. K&N recommends to run them with a bit of dirt on them. Last year I decided to clean it in soapy water. Let it dry and lightly, repeat, lightly re-oiled it. A year later, truck still runs fine with 90K miles on the odo.
