1969 door panels
1969 door panels
Well today I put my door panels back in since handles/locks/crank are all finally working.
I realize I need now door panels and they are on my list but not at the top of it just yet. So I have two problems and wondering what other people have done. I am considering long screws to keep the panel properly in as I sacrifice these old warped panels till I get to new ones.
Anyway,
1. how do you get the panel to stay snug to the door, I can't get the little velcro like plastic bits to attach to each other. (this is where I am considering 3 inch sheet metal screws until I get new replacemnts?
2. What piece am I missing at the base of the window glass, is it part of the interior door panel that would cover this metal bit?
3. unrelated but does anyone know if either of these two items are factory. I assume that one may be tribometer reset but not even sure of that as it does nothing. As for the other one, any ideas
As always, thanks for any ideas.Pete
Anyway,
Received 1,469 Likes
Cruise-In II Veteran
Black J bracket in pic one slides into a pocket on the back side of the door panel, then screws to the door. There's a second one on the front of the panel.
Second pic shows left over reinforcement for old door main weatherstripping.
Switch and **** in pic 3 is not factory. Rusty bracket behind it could be factory and is holding the odo reset cable. **** is missing..
FWIW: do you have the assembly instruction manual (AIM)?
Received 2,878 Likes
Hi V71,
I believe I would remove the door panels and try to determine if the 'fasteners' can be repaired before putting screws through the panels.
Perhaps these pictures will help you see what's a little more typical.
Regards,
Alan
The missing weatherstrip.
Regards,
Alan
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Its obvious that the J clip has pulled through the door panel on the back side. What you might consider doing is patching the pocket it slides into and then re-attach it to the panel and install it back on the door. You might try something like Plastic Fusion or some other epoxy that will stick to the back side of the door panel. It looks original so if it is it'll be made of fiberboard and won't be an easy fix.
Mike nailed the other questions you had. And lastly.. door panels are on sale at this link https://www.corvetteforum.com/forums...tarts-now.html
Thanks so much for the help everyone. Alan as usual your pictures are spectacular and thanks so much Wilcox and Mike.
I do have the AIM which I got from Wilcox but as most know, it can be a bit hard to follow at times. My doors are the fibreboard and the person before me must have been a bit heavy-handed taking them off. I will try a temporary repair as they will be replaced next fall.
Thanks again guys.
Thanks again guys.
Received 3,220 Likes
I've got some original fiberboard panels as well.
I used some of these 'Magdaddy" magnetic mounting plates on the back of the panel- as the door's inner structure is metal. These work great!!! A few bucks apiece- Summit Racing sells them.
http://magdaddyusa.com/products/all-...agnetic-plate/
My old panel ripped off the clips.
So I bought a new one for my 69 and it also won't lay flat against the door.
I have to push hard to get the clips to align so they are just going to rip off again.
Richard got any pictures of these magnets installed? Are both sides just glued in place.
That looks like it might keep me going until next fall. How did you attach them to the fiberboard? I am surprised the magnets are strong enough.
Pete
Just need the magnet- as they'll stick to the door metal skin great!! These are really strong!! I'm going to dab some fiberglass resin to hold them into place.
I am customizing my original door panels- To stiffen them up and make them curve to fit the door- I flexed them using some wood blocks and some C-clamps, then took some fiberglass resin and brushed the back of the panel- and it worked great!!!
Panel fit- nice and tight!!!
here's the one you can mount w a screw-
Are they strong? YEP!!!
