Starter Numbered?
Received 2,878 Likes
Hi V,
Yes.
The starters all have a stamped part number that indicates their application and a stamped date code that indicates when they were assembled.
Both make them appropriate for certain cars.
Regards,
Alan
The part # indicates an early 71 model year, 350 cu.in., 4-speed starter.
The date indicates January 5, 1971. '1' the year, 'A' the month, '5' the day.
This starter is on an engine in a car produced mid-January, 1971.
Yes.
Regards,
Alan
The LS4 starter ended with a 9 for automatic. May not have even been made for a Corvette.
Aside from the numbers would it matter if starter not made specifically made for a corvette? It fits perfect with no clearance issues. Only reason I dropped it is to swap out for a broken selenoid cover.
Hi V,
It sounds like you've been using it without a problem, so the stamps wouldn't be enough reason to change it at this point.
Regards,
Alan
Regards,
Alan
Vettesic (06-01-2016)
