Weird turn signal problem
My 69 has a strange turn signal issue going on, when the ignition switch is in the off position the turn signals still work and they flash at a normal speed, when the ignition switch is on they flash very fast. I've only had the car for about two months, I'm trying to fix all the issues it has. I can tell that the turn signal switch isn't original, it has an adapter harness to connect it to the car's wiring harness. I'm guessing that the problem is in the turn signal switch but I'm not sure. I would like to replace it with a switch that plugs directly into the wiring harness without the need for an adapter harness, is one available new? Has anyone else had this problem? If so what was the cause?
as far as slow when power off fast when power on,
If I was gonna just toss guesses, when the key is on they are getting far more/better power for some reason, the flasher is getting hotter in turn flashing faster,
This is one you really might wanna post some pictures, do you mean the switch is the rat rod clamp to column type or just generic of some sort with an adaptor at the wiring,
Does anybody know what the factory GM part number is for a turn signal switch in a 69 vette WITHOUT tilt/telescopic steering? There's a bunch of NOS switches on ebay but most of them don't specify if it's for a car without tilt/telescopic steering. The ones that do specify what it's for are for vettes WITH tilt/telescopic steering. I want to make sure I get the right switch the first time around, I don't want to buy one and then find out it's the wrong one after I take the steering column apart to install it.
He will know just what you need and also know if a better version is made, some stuff on ebay regardless of where it's made is junk, and that isn't a job you wanna do twice
Willcox Corvette (06-07-2016)
Willcox is out of stock of the switch I need. The turn signal switches I'm looking at on ebay are NOS AC Delco turn signal switches, not aftermarket switches. The ones that are offered by Willcox, corvette America, zip, and eckler's are aftermarket reproductions. Given the choice I'd rather have an original NOS AC Delco switch over the reproduction switches offered by the corvette specialty shops which is why I need to find out what the original Delco part number is for a 69 vette turn signal switch without tilt or telescopic steering so that I can get the right NOS AC Delco switch.
Have you checked all of your lamps, a lot of cars do a rapid flash when a lamp is dead. With that said, I have no idea about the C3, I haven't had mine running in years. I doubt this is the cause on such an old car.
Update:
I've determined the cause of the rapid turn signal flash, it was the turn signal flasher. I replaced the turn signal flasher and now the signals flash at a "normal" speed. Here's where it gets weird again though, when I remove the hazard light flasher from the fuse box the problem with the turn signals working when the key is off goes away. And the hazard lights still work without the hazard light flasher, they flash using the turn signal flasher. Without the hazard light flasher installed everything seems to work like it should but when you put the hazard light flasher back in place the turn signals will work with the ignition switch in the off position.
The turn signal switch, hazard switch and even brake lights all work with/through that turn switch, it changes who does what depending on what's pressed, pushed or turned on, when things have bad or no ground odd things will happen, when a bulb it burnt odd things can happen,
My brain never booted today but something isn't wired correctly,
The hazards should not flash using the turn flasher.
the hazards should work even with no key.
Yeah I'm at a loss now as to what's going on with it. I just tried it again, this time with the hazard light flasher installed and the turn signal flasher removed. The turn signals work using the hazard flasher now and they work with the key in the off position again. The hazards work with the key in the on or off position (like they're supposed to). When I tried it with no hazard flasher and just the turn signal flasher the signals worked like they're supposed to (when the key is in the on position and not when the key is in the off position) and the hazards worked too but only when the key was in the on position. All the bulbs work so I don't think the problem is with a bad bulb. What is wrong with my car? Could the problem be in the turn signal switch?
example, my 87 fiero has a factory flaw to correct it one has to switch the wires on the temp sender and switch two wires in the dash plug,
Anyway, go back to this adaptor plug I believe that is the puzzle piece at the moment.
Things are getting power when they are not suppose to, from what "I saw on the net that adaptor is to make one switch fit more...
On the older GM flasher sys. the turn signal flasher unit controls both the turn signals and the em flashers and it does not use two flashers .Maybe the adapter is converting an older style unit to you're newer style vette turn signal system . So if that is the case than you would only need the one flasher than when you install the new original turn signal you'll have to put the em flasher unit back in.
Pete
Pete
Pete
Pete
but I do believe the adaptor plug is a key to this puzzle.
Does your turn signal switch plug directly into the wiring harness or is there an extension/adapter harness between the plug on the switch and the plug on the harness?
Good news, I fixed the problem, yay! I replaced the turn signal switch and everything is good now, no more weird issues. Everything works like it's supposed to now. The switch was an aftermarket replacement that I bought at a local O'Reilley auto parts store. I know, I said I wanted to use an NOS AC Delco switch but I decided to try an aftermarket switch from a local auto parts store instead because I didn't want to wait a week for an NOS one to arrive from ebay, I wanted to see if I could fix it today. Man what a headache that was, it was a real brain burner trying to figure it out. What made it even worse was working outside on it in the 110 degree heat we had today (I live in Tucson Arizona). I felt like I was gonna melt, lol. Thanks for your input in this thread though, if the turn signals in your 69 ever start doing the strange things that mine did you'll know what to do to fix it.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ernie
The13Bats (06-07-2016)
So Tucson, I am in Eustis fl, and it's like a sauna most days, not as high as your numbers but, I saw a bird flying by burst into flames,
There is a part near Tucson I cant get home to Eustis, you hauling any truckloads this way....
