Looking for Small Diameter Steering Wheel
I have recently installed C5 seats into my C3. I am having a hard time getting my legs between the wheel and the seat. My current wheel is the the typical 14" diameter. I am looking for 13" or preferably 12". There are plenty of web sights that claim their wheels are universal and will fit but will require an adapter plate...of course they don't sell those.... so really dude, your wheels don't fit....correct? Anyway, dont get me started on aftermarket "bolt-on" parts.
So....does anyone have any recommendations of steering wheels that will actually fit a 1972 non-tilt steering column?
Thanks!
Thanks!
I have seen one of the vendors offer a wheel that I think is 14” but it also is flat along the bottom, think of the letter D, I have contemplated getting one as I have the same issue
Thanks!
Thanks!
These wheels (Nardi, Personal, Momo) are not inexpensive, but they are high quality. The Personal wheel has been on my '73 now about 30 years and it looks terrific. Any vendor that sells these wheels will also sell the adapters. The Nardi wheels have more of a classic sports car look while the Personal wheels are a bit more modern looking.
If you need the name of a vendor that carries them, just send me a PM.
Good luck... GUSTO
Thanks!
Thanks!
http://www.ebay.com/sch/i.html?_from...wheel&_sacat=0 notice the screw holes on the wheels match the oem ones on most.
? Ebay is loaded with aftermarket direct bolt on wheels as well as corvette america, ecklers mid america amazon... the 76 is the oddball though.
Gotcha, My stock wheel is 15" like this 69-75 one, a 14" wheel seems a lot smaller.
http://www.ebay.com/itm/1969-1975-Co...pXFa-l&vxp=mtr
I doubt you'll find something as small as 12" but its easy enough to drill holes in a new wheel if you cant.
My uncles c3 came with a smaller steering wheel (like 13") and he does not like it. It does have an adapter though which adds about 2" of column length. due to the older steering system I think it makes it awkward to steer with the smaller wheel.
I bought a 13-1/2" leather-wrapped [black' wheel, with similar spokes to the stock C3, from an east-coast vendor. They still sell the wheel for $99. It's a perfect fit and does not have a larger center hub that sticks out from the horn button O.D.
I used some vinyl dye I had mixed from my interior to re-color the leather on the wheel (after wiping down with lacquer thinner, first). Worked great and no discoloration, cracking, or chipping for 5 years+.
Send me a PM if you would like the vendor's info.
So, not being able to get straight answers from most places that specialize in steering wheels and the pathetic selection for our C3 Corvettes I just figured it out myself. Sparco was able to provide enough information to allow me to determine that their steering wheels would be close regarding center hole and bolt circle diameter. I managed to find a 13" wheel with a flat bottom that worked perfectly. See pics below. All I did was elongate the existing holes for the horn assembly and drill new holes for mounting using the existing steering wheel as my template.
The following 2 users liked this post by KJL:
PhenyxC3 (12-03-2023),
StingrayBob (06-20-2022)
I am 6'5" or was, about 20 years ago....I kept my '72 seat but dropped the back mounts outta there, so it's lowered about 2" in rear, cut the carpet/liner out fron the front bolts also....I have a '78+ TT column in there with a 14" wheel covered with those wraps you pick up at parts houses.....I still had wheel/leg problems.....so about 15 years ago I cut the floor/firewall across and below the steering wheel...pushed it forward about 3 inches and glassed it in.....cut/welded the brake pedal to push it forward, heated and bent the gas pedal lever so both of them now fit fine....since then I converted to hydroboost brakes with about a 2' travel, and MUCH better braking.....another topic....
but with a 14" wheel even my legs clear the wheel FINE now there is basically no other solution for ME, anyway.....dunno nuttin about other seats, just remember that one of the prime reasons for my selling my '87 vette was at that time a issue with seating comfort that has NO solution, width and all those silly bolsters....
I drive in the James Dean slouch position. right elbow on the console pad, left hand on the rack steering......SNORE comfy......
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,920 Likes
Received 1,731 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
What exactly was the difference in bolt pattern? It looks real close, just maybe clocked a little different? Could you have mounted the "hub" differently to get the holes to line up?
I like the idea and looks of the old school big wheel, but I need something smaller as well.
Kubs (08-24-2016)
