EX TV Cable Adjustment
I've just finished installing a Monster Transmission Stage 2 rebuilt 200-4R trans in my 77, with the Bowtie Overdrives EZ TV system. The 1-2 shift seems late, and hard at part throttle, and I believe the TV cable is adjusted correctly. Does anyone have experience with the adjustment on the BTO linkage at the carb? I currently have the oval piece in it's lowest position, but I don't see anything in the instructions about what raising or lowering it is supposed to accomplish. Any suggestions?
Put a gage on the pressure tap left side of case. You will see an instant increase in pressure as soon as the throttle is cracked open, that means the adjustment is correct. The late shift is probably due to the governor, the one in my Regal turbo transmission shifted late too, it's the way it's calibrated for the application.
ted13b (06-14-2016)
Stage 2 will have a firm to hard shift no matter what. The TV cable can be played with, a few clicks looser may give you the shifting point you want but always error to the tighter side for trans longevity. If this doesn't work for you, there's a half dozen other ways to adjust it but it's much more involved
ted13b (06-14-2016)
Thanks for the responses guys. I like a nice, crisp shift, and the 2-3 shift is great, but sometimes, especially cold, the 1-2 shift comes late, around 2500 RPM, and really slams into gear. I guess my real question is by raising the EZ TV linkage, how will this affect the shift points? Will it make the shifts at a lower RPM, or higher, or no difference?
The TV cable controls line pressure, the governor controls shift points.
ted13b (06-14-2016)
So a late, hard shift would be the governor? And I'd want the line pressure tight, to keep the pressure up?
I had the same issue as you with my 200-4R. I hated the late shift and stage 2 set up was too hard shifting for my liking.
The BTO linkage allows you to keep tension on the valve in the trans body but at the same time adjust the rate of the cable moving the valve this means you can adjust this to suit what you need without having the cable loose at the all important time when you start to step on the gas. This is my understanding of what it does at least.
In my case the 1-2 shift was late at part throttle but at WOT it was too early as was the 2-3 and 3-4 shifts. The BTO linkage and one of their springs in the valve helped somewhat but in the end the only way I could get the 200-4R shifting the way I wanted was to change out the whole valve body and use a modified one from CK performance as well as a modified governor. The transmission will now up shift at under 2000 rpm when I give it barely any gas but will hold onto the gear to 4500 rpm on WOT.
I found with this set up the BTO linkage seemed to make little difference so I took it off. The whole transmission change turned into a very expensive and time consuming exercise to get it the way I wanted and if I was doing it again I would seriously consider using one of the transmission options that I could plug a laptop into so that shift points can be changed easily. JMPO
ted13b (06-14-2016)
My 200-4R had a shift kit in it when I bought it, and I used the bowtie overdrives EZ TV cable. Pressure at idle was high and the pressure rose higher as the throttle was opened. I think that's what you will see with yours.
ted13b (06-14-2016)
I like a firm, crisp shift, but this is a late shift that slams into gear and kicks you in the back. It's actually embarrassing. I'd like to find a 300psi gauge locally, any suggestions? I tried the Harbor Freight web site, but they don't list any that high.
ted13b (06-18-2016)
With a new tranny, just call the trans vendor and tell them you want the 'regular' shifts to be less firm. Ask us about it when the vendor or trans manufacturer fails to solve your problem. We're just the "second string" in this case.
ted13b (06-17-2016)
ted13b (06-18-2016)
Really hate hijacking the thread, but do you have the part numbers for your modified valve body and modified governor. I have a shift kit in my 200-4r, but my WOT 1-2 shift is great, nice little chirp, but my 2-3 and 3-4 shifts are at about 3300. I have the stock VB and governor. Thanks.
ted13b (06-18-2016)
Modify the governor to lighten the shifts. Add that spring back (assume this means springs restricting movement of the fly-weights). If that doesn't get enough change, increase weights.
ted13b (06-18-2016)
ted13b (06-18-2016)
The only thing that changes when you rotate that cam assembly is the rate at which you pull the cable.
The distance that the cable is pulled stays exactly the same.
If you would like your part throttle shifts a little sooner and softer,
then you rotate that cam assembly clockwise and you should be able to feel some difference.
ted13b (06-18-2016)
I might be wrong, but I didn't think that changing the weights and springs on the govenor would lighten or firm the springs, i thought that it only dictated shift rpm, loke i said, maybe I'm wrong, but as far as I'm aware the only real things that will lighten or firm the shifts are the valve body/shift kit and the TV cable.
ted13b (06-18-2016)
One thing I know for sure about 2004R trans TV cable is: There is only one way to properly adjust it. Any adjustment other than that shown here will cause shifting problems. The diagram is off of the Art Carr website. This man knows as much as anybody about these transmissions. Make sure your measurements match those in the diagram for best results. I used this when setting mine, and I get great shifts.
ted13b (06-18-2016)
