Holleys ne Stealth Ram MPI
I was wondering if anyone else has noticed this ?
Do you see any pros or cons on this system? is comes with their Commander 950 control system.
This looks just like the thing I've been waiting for :yesnod: .
You can read more on it at : http://www.holley.com/HiOctn/NewsInf...NR021202U.html
:cheers:
:cheers:
1 Post
Re: Holleys ne Stealth Ram MPI (SmokedTires)
GREAT!
Now will it fit under our hoods? Even with a hi rise/l-88 is might not since the throttle body sits so far forward. Let's see about a group order. :)
Re: Holleys ne Stealth Ram MPI (Fevre)
i dont think itll fit under a stock hood i looked at that same system before i started my project.it might fit under your hood mike.
I thinking it'll fit under my hood I have now, but would be great if it'd fit under the L88 hood since that's the hood I'll probably go to when I paint the car. NOw if I can just come up with the cash for this thing :rolleyes: , I am working on it ;) .
Pat how is your car running with your new setup ? I love the cold air setup :yesnod: .
1 Post
I am debating on what Fi system I want. Have heard the stock tpi pters out at 5500 but sure you can juice it up for higher rpm's but more $. I am looking at TPI, L98 or Holley MPFI. :confused: What I need to find is a donor car with FI and 5 or 6 speed trans. :yesnod:
[Modified by Fevre, 2:57 PM 9/9/2002]
Fevre I've been drooling over the Accel SuperRam for about 3 years now but I just convince myself to spend $3000+ for it, this new unit from Holley is about $2200 from Jegs which is MUCH better cost wise to me. I once was considering the stock Chevy TPI units, but chickened out because I wasn't sure if there was enough support or possible compatibilty problems with the motor & finding the correct PROM to work.
Here's a website that's dedicated to swapping in a :chevy TPI unit from 1985- 1992. http://www.chevythunder.com/index.htm Maybe you can find out any questions you have on them there :) .
[Modified by SmokedTires, 6:25 PM 9/9/2002]
mike i havent fired it up yet waiting on a few more things to come,i upgraded to 24 lb injectors so theyll be here tommorrow,and trying to get slp runners on ebay been outbid 2 times so far.i might just wait till englishtown swap meet in 2 weeks and get them there.Fuel pump is done and in the tank just have to put the tank back up tommorrow.,also the custom chip isnt done yet,but i might fire it up with the stock runners and stock chip for now,to seehow she runs.
Re: Holleys ne Stealth Ram MPI (pats406nitrovette)
Car craft has an article on the Stealth ram this month. looks wicked! They say it will fit under a stock 3rd gen camaro hood, so I figure it will fit under ours!
Pat the blue runners you have on now look really :cool: . I'm anxious to hear your results. Did you use your stock tank to mount the fuel pump into, & if so how was the install ?
Thanks Mike, I'll be sure to pick up a copy :yesnod: .
