Angled plug heads, headers and factory side exhaust
Dementer sole survivor
Received 6,296 Likes
2016 C3 of Year Finalist
This is what my setup looks like. Nothing fancy. Actually Hooker super comps. Not the Headmans like I stated earlier.
Drivers side from front
Passenger
Drivers side from behind the front tire
Name of the header
You can see the plug goes stright into the header, might work for angled plug head. Middle bottom you can see the angle of the lower pipe
This setup works great in my car. I havent put my angled plug heads on yet. Probably late sept. I used thick aluminum header gaskets, they came pretty thick and the directions say you can layer them to get the clearance you need. I actually didnt use all the gaskets in the pack so I might add some once I change the heads.
Passenger
Name of the header
The center 2 plugs could pose a problem running into the front and rear pipes with angle heads looking at the last pic.
rebuild (08-02-2016)
