Big block fuel pump pushrods?
Old 07-25-2016, 12:18 PM
Duntov
Duntov's Avatar
Default Big block fuel pump pushrods?
Since this is the first big block that I'm doing, do stock LS5 454s use a fuel pump pushrods, and if so which one? This is the original engine and will be going with original style fuel pump.
I'm trying to get the majority of the parts ready to order in the next couple of weeks.
Old 07-25-2016, 12:53 PM
crf311
crf311's Avatar
Use a stock push rod if your using a stock cam. If you are going to use a roller cam you will need a rod with a hardened tip.
Old 07-25-2016, 01:02 PM
Duntov
Duntov's Avatar
Are they same as the small block ones?
Old 07-25-2016, 01:15 PM
bashcraft
bashcraft's Avatar
Yes.
Old 07-25-2016, 07:27 PM
Duntov
Duntov's Avatar
thanks. That solves one issue
Old 07-26-2016, 09:50 AM
Jebbysan
Dr. Detroit
Support Corvetteforum!
Jebbysan's Avatar
Received 3,892 Likes on 2,564 Posts
I like the hollow ARP unit......
https://www.summitracing.com/parts/a...8701/overview/
Jebby
To Big block fuel pump pushrods?
Quick Reply: Big block fuel pump pushrods?
