Is this a driver's side or passenger side exhaust bezel?
I need to make the openings in my aftermarket 70 rear clip for the exhaust bezels using the bezels but I'm not sure which one is the passenger side and which one is the driver's side. Which one is this?
Received 2,878 Likes
Hi P,
The one in your picture is the left side bezel.
Regards,
Alan
They aren't interchangeable because one side of the bezel is contoured to fit the quarter panel and the other is contoured to fit the valance panel.
Regards,
Alan
Priya (07-26-2016)
Hi P,
I added a picture after you replied.
Regards,
Alan
Regards,
Alan
I could see the two were different but as there was no cutout for the exhaust bezels on the aftermarket clip I couldn't hold them in place to see which one went where.
Hi P,
Are there any fiberglass 'flanges' mounted in the clip to support the bezel?
Is there any guide for you to determine where to cut for the bezels?
Regards,
Alan
Regards,
Alan
No, I was planning on holding the front of the bezel against the inside of the rear clip/exhaust filler panel, drawing a line, shaving up to about a 1/4 or 1/2 inch from the line, test fitting, shaving a little more, repeat, until the bezel fits in place.
Hi P,
Perhaps it would be a good idea for someone to give you a dimension for the distance BETWEEN the 2 'inner' flanges (opening to opening) which at least give you something to get started with.
The way the the bezels are made their outer edge configuration can hide a 1/4" inch goof, but not much more than that.
Is the underside of the clip shaped in such a way that you can hold the bezel against the glass and trace a line inside the bezel for you to follow?
Regards,
Alan
Regards,
Alan
Hi P,
Regards,
Alan
Regards,
Alan
It would be helpful if I could get an inside diameter measurement of the distance between the vertical flanges on a finished car.
Hi P,
33-5/16" from surface to surface.
Regards,
Alan
Regards,
Alan
Priya (07-26-2016)
