sagging rear - one side only
ive got a 78 vette, with vbp 330 mono spring, qa1 double adjustable shocks, ive noticed recently one side the rear end is sagging by alot, 2 inch approx, the body is sagging on one side, so wheel to wheel arch is about 1.5-2 inch approx, what could cause this, can the vbp mono spring lose its strenght on one side, thus causeing sag??
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Have you checked the rear body mounts? They have a pretty good history or rotting out, either the mount itself or the metal cup that sits on top of it.
Also, how does the front look left to right, possibly a weak front spring
It could be the rear spring, how old is it? Vbp has a very reliable history for making awesome parts but anything is possible.
Willcox
Willcox
Willcox
Willcox
if i wind up one nut on one side the body comes come up, but its wind up 1 inch there, and body is then just about level to the ground at that point, but that looks wrong, because the com spring wouldnt work correctly??
see in pic
Ive noticed car is down at front corner on the same side aswell, by 1 inch, tried swaping composite spring over, so hould have sagged on other side, but not doing that, still sagging on same rear corner and the front on the same side, any help?
could that be an issue, its brand new so shouldnt be bent, looks good??
can the bolt/nut lenght affect car?, how tight the nut is?
If the bolt is significantly tighter/ compressing the rubbers more than the other side, it could have an effect. One time I used a shorter end link spacer on one side to correct this problem after making sure all else was ok.
I unbolted the front sway bar, just case it was bent
jacked up rear end, measured the gap between top of arch to metal part of wheel on both sides, both measured the same, then unbolted each side of spring, leaving it bolted to diff, and we can clearly see from pics that each spring bolt on each side is showing a different lenght, which leads me to think the spring has a big problem, am i right, or am i missing something?
Did you ever get an answer? I've got the same problem on my '76 but not as much difference. Also have the same springs you have.
