1982 Corvette Fuel Tank Recommendation.
I removed my fuel tank and need another one for a 1982 Corvette. Can anyone recommend a good vendor? I am looking for a decent tank with a zinc coating or something comparable. Liner or no liner.
Zen Vet Master Level VII
X2
No mistakes there. While you have everything apart, consider replacing your fuel pump with a 85-89 Vette model. It is a direct bolt in and it increases your fuel pressure-- lots.
, or Zip... they have it for $230 and you could ask them for the Carlisle discount (free shipping if you stop by their tent at Carlisle)...
photo courtesy Zip Products
http://www.zip-corvette.com/68-82-c3...-gas-tank.html
Good luck... GUSTO
Good luck... GUSTO
Platinum Supporting Vendor
We have them, I don't know I would use the 85-89 pump though, those are designed to flow a much higher pressure and without other modification that would not be a good thing.
One last note on the TB rebuild kits, get the Sorenson kits from Autozone, they are good kits and have the "correct" bladders, trust me on this. P/N: 96-629 I think they are around $45 still. There are other kits available for CFI TBs. However, they are not all the same quality and they all do NOT work properly in a CF.
Nice! Just a suggestion, but before you install the new tank make sure you install new anti-rattle strips on the tank bands. You can buy them at a few corvette places, but you can use roofing felt cut to the correct measurements at a cheaper price. The ones you buy are going to be the same thing and cost more. Just a tip on that.
