Vac. hose routing
Vac. hose routing
Last week I had to replace the pass side exhaust manifold and put different valve covers on. In so doing I have gotten the vacuum hoses all put back incorrectly.
Please check out my picture and tell me if there is 2 EFE switches mounted on the thermostat housing.
I cant find another picture of a 79 L48 with 2 switches.
Thanks for looking!
Thanks for looking!
look at the diagram in this link it should be similar if not identical
http://repairs.willcoxcorvette.com/1...l-vacuum-hose/
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The links posted is dead for some reason, I'll have to fix it later. Fixed.. Melwff, if you want to mark it here is the good link. http://repairs.willcoxcorvette.com/1...ission-vacuum/
1978
1979
1978
1979
efe
Here is a better picture of what I am talking about. Is there 2 efe switches on the thermostat housing.
The diagrams from Willcox only shows 1 switch.
See below. The third vacuum switch connects into the distributor vacuum advance. Note this is from a 1980 assembly manual. For whatever reason when I bought .pdf versions of the manuals for my '79 I got '78 and '80 assembly manuals. The '78 assembly manual does not show that third switch and it is not present on my '79 L82 engine.
VAC. issue
Thanks Mike for the reply. None of the diagrams I have seen seems to match my motors vac. hose routing. Too complicated for my feeble mind. Gonna hunt a corvette guru I guess. Car runs ok but rough idle.
Former Vendor
Try here. Perhaps the 1979 California diagram? Again it appears that the third switch is for the distributor vacuum advance.
Former Vendor
michaelroy (08-29-2016)
