Holley Carb Question
Old 08-24-2016, 08:20 PM
spedaleden
spedaleden's Avatar
Default Holley Carb Question
Have a Holley 670 and engine is sucking fuel when car is shut off. The fuel pressure gauge used to have pressure when engine was off and would loose pressure overnight. now once I shut off engine fuel pressure is at 0 and when you restart the car it acts like its flooded
Any ideas
Thanks in advance
Old 08-24-2016, 09:52 PM
cagotzmann
cagotzmann's Avatar
Any ideas
Thanks in advance
Seems you may have a float problem in the carb. If the fuel bowls are full they should shut off fuel supply or there is a leak from the fuel bowl which leaves the floats open to release the pressure.
Once you shut off the car check if fuel is dumping into the intake.
Old 08-25-2016, 07:44 PM
spedaleden
spedaleden's Avatar
You are right on, I reajusted the float and we're all good. Fuel gauge is holding pressure again.
To Holley Carb Question
Quick Reply: Holley Carb Question
