High Stall and lockup question
Old 08-26-2016, 10:56 AM
Bloodzone
Bloodzone's Avatar
Default High Stall and lockup question
Could a 3200 stall prevent 700r4 from locking up in OD at normal driving speeds of 65-75?
Old 08-26-2016, 11:14 AM
diehrd
diehrd's Avatar
No. You can lock up at any speed in any gear with a 700R4 , many stock GM cars and light trucks had stall speeds as high as 2800 from the factory . ( 4cyl , V6 )
Old 08-26-2016, 11:25 AM
Bloodzone
Bloodzone's Avatar
Where/how is this adjusted? Not sure I'm asking this correctly. I know little about transmissions.
Old 08-26-2016, 11:34 AM
gkull
gkull's Avatar
Received 1,330 Likes on 1,058 Posts
My 700 was set to only lockup in 4th gear OD using a manual toggle switch. but anyway what activates your lockup? You should have 12 volt wires activating the " lockup solenoid" but something has to cause the lockup function.
Bloodzone (08-26-2016)
Old 08-26-2016, 11:38 AM
bluedawg
bluedawg's Avatar
Mine locks up in fourth as well being a 3k.
Old 08-26-2016, 11:54 AM
Bloodzone
Bloodzone's Avatar
Using a 12V switch thats not manual. I've been told from 2 different sources that its wired correctly. I verified that my converter is a lockup converter.
I have a large external cooler. Heat is not a issue. Far as I know only thing its costing me is a few MPG. But I would like for it to work as intended.
Old 08-26-2016, 01:02 PM
diehrd
diehrd's Avatar
Lock up is activated by a 12v signal usually done automatically once your in 4th gear and in many stock cars it would auto lock up in 3rd gear. It requires a pressure switch in the valve body and a 12v source.
Search the internet for lock up kits , it is straight forward .
If you have a 1980 to 1982 the car comes set up with a lock up signal system already
To High Stall and lockup question
Quick Reply: High Stall and lockup question
