Clunk when downshifting
I have a 69 bb 4 speed coupe and when downshifting to slow the car I sometimes get a clunk coming from the underside of the car. Also, when in third gear and decelerating, the car sometimes pops out of gear.
My question is are these issues related? The car is currently in the shop to have these along with a few other minor issues inspected. I was told the drive shaft was out of alignment so they are sending it off to be repaired. The u-joints checked out ok. Do I have a transmission problem? I was also told when they removed the yoke from the transmission after pulling the drive shaft that it had some wear to the end that connects to the transmission. They said it was chewed up.
Should I have the transmission pulled and rebuilt?
When you let off and it pops out of gear it (in most cases) are the syncros. The gear has part of the syncro on it and there is a syncro clutch which is the shift slider. That could be out of adjustment (linkage) but when a gear grinds it is the syncro part of it grinding against the clutch ring in the trans.
The clunk can be your differential rubber snubber. If the yoke is bad along with popping out of gear, a good trans guy can cut thru the chase by checking the linkage, then taking the side cover off the trans.
A few bad shifts under power can dull the dog house parts of the syncro that is on the gear and clutch ring. the brass part of the syncro only slows the gear down to engage it.
Dom
Dom
Received 1,468 Likes
Cruise-In II Veteran
