*Video* starter hitting flex plate.
Old 09-01-2016, 05:07 PM
ScottieS
ScottieS's Avatar
Default *Video* starter hitting flex plate.
I've never had any issues with this before so I'm a complete noob on this topic. This happens when the starter is warm or cold. It also happens only every so often. Here are some really short videos to show you guys exactly what's happening.
Any ideas?
Old 09-01-2016, 06:21 PM
Jamess411
Jamess411's Avatar
Couldn't get the vids to load…..what is happening?
Old 09-01-2016, 07:07 PM
ScottieS
ScottieS's Avatar
It's literally just the starter cog hitting the flex plate and backing off when I turn the key. I found I can just turn the cog by hand a bit to move it a bit and then it will mesh with the flex plate when I use the ignition
Old 09-02-2016, 12:15 AM
gkull
gkull's Avatar
Received 1,329 Likes on 1,057 Posts
You need to shim or unshim the starter to attain about 50% tooth engagement when you kick the sel on
Old 09-02-2016, 04:27 AM
mrvette
mrvette's Avatar
On the starter I just did on my staggered bolt '89 truck block 350 engine in the vette....it is a standard rebuilt starter.....they supplied two shims and a allen wrench because it had a 1/8 inch across the flats, hold the wrench between the shaft and the flywheel teeth to check clearance, shim as necessary....
Old 09-02-2016, 12:11 PM
ScottieS
ScottieS's Avatar
If it needed a shim wouldn't it just never start though?
Old 09-02-2016, 07:54 PM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
If the pinion gear teeth happen to be perfectly lined up with the ring gear teeth when you hit the key, they mate just fine and it starts right up. Adding some extra clearance by shimming helps the teeth engage more easily when they aren't lined up just right.
To *Video* starter hitting flex plate.
Quick Reply: *Video* starter hitting flex plate.
