Misfire but all eight show spark?
Another misfire mystery I cant solve. One day it seems fine the next I have one cylinder not firing but cant tell which one. Put timing light on all wires at idle and all eight had consistently same pulse. Fuel issue/starvation wouldnt cause one cylinder to misfire.
Was thinking if I drive around while its missing, could I pull over and use heat gun reader and check header tubes and see which one is colder? Doesnt miss when idling or at least I cant tell. Also checked cap, dwell, timing, pulled plugs and all is perfect. Still could be a bad plug not firing correctly I guess so maybe I will first try new set plugs.
All ideas appreciated.
What do you mean by miss-fire? Popping in the exhaust, etc..?
In the past I had somewhat of the same issue. The plug wire was backing off of the spark plug about a 1/4". Just enough that sometimes it fired, sometimes it didn't, but with just a casual look they all looked like they were on properly.
The next time you have the problem, try pushing on each plug wire at the spark plug. See if one has backed off a bit.
Surfer69 (09-16-2016)
Do check that the leads are all on the plugs properly as suggested, that's caught me out before too.
prob an arcing plug wire, look under hood in dark garage with someone (non-goober) holding brake and applying light throttle while in gear....say 1200rpm. look for arc to manifold or other metallic surface.
What gap do you use for the plugs? Under pressure in the cylinder, a plug could missfire if there is high resistance upstream from the plug. Sounds like you have checked most of these items though.
You definitely will get a miss fire in one cylinder under lean conditions caused by mixture distribution problems. This could be magnified by running too large sparkplug gaps.
Dr. Detroit
Received 3,891 Likes
Dark garage as stated will tell you a lot.......
Also watch out for overcharging......if the voltage gets above 15 or so, it can mimic a misfire....
Use dielectric grease on both ends of each spark plug wire......
Jebby
Jebby
Received 3,043 Likes
St. Jude Donor '05
Bad wire
Go get some cheapos from the auto parts and try them
If you have a 'points' ignition, you might replace the condenser [in the distributor]. And, if you have just recently changed it...then you should change it again, as the one you just installed is likely defective.
Other possibilities are: cracked distributor cap; bad coil; POOR GROUND CONNECTION TO THE DISTRIBUTOR (dizzy body to metal hold-down clamp to engine block) many folks paint that stuff and are unaware that they just lost distributor ground.
Now that you menmention it I've had this before. The ground connection under my cap was loose. Behaved just like the OPs. Everything seemed fine at idle. But when driving it would randomly start missing, and then go away for a while (sometimes a few miles sometimes a few days). Wasn't until I was going to try a new ignition module that I found it.
OK just replaced plugs and found again number 2 black with medium tar gook on it. Drove around with new plugs and seems good like its gone now except my hesitation around 4500 is still there...but thats another thread.
Need to figure out why #2 is getting oil in cylinder. Maybe need to tighten head or something or rings are letting bypass get in.
Might be as simple as a bad plug wire or misassembled connector in the wire. You can check them with an ohmmeter. Remove wire from plug and other end from dist cap. Check resistance. If any of the wires have much higher resistance than others, replace them.
CanadaGrant (09-25-2016)
{not if the #2 plug wire is bad...}
