1978 Y Pipe different between L48 & L82
Trying to buy a replacement Y pipe for my 78 L48 automatic Corvette and I'm wondering if there is a difference in the L48 and L82 Y pipe?
I found a Walker Y pipe that is an exact replacement, but doesn't list the different engines, but other sites do.
https://www.ebay.com/itm/361527760627
thanks everyone!!
thanks everyone!!
If your are looking for more performance from your car take it to a good muffler shop & have 2 1/2' duals installed, then re curve your distributor.
This is a performance up grade.
Oh by the way your manifold outlets are 2"
Good luck
Good luck
AS for cost if you can find an exhaust shop to bend the pipes it could be cheaper than the ones you linked, ditch the cat and recycle it help offset cost. Use one of these x pipes
http://www.ebay.com/itm/Universal-Cr...lXpJO~&vxp=mtr
