Looking to replace wiring harnesses on a 72 any sugggestions?
Old 09-29-2016, 09:38 AM
J Mo
J Mo's Avatar
Default Looking to replace wiring harnesses on a 72 any sugggestions?
Any suggestions on where to buy from, any specific manufacturers. Want to replace engine and dash harnesses.
Thanks,
John
Old 09-29-2016, 09:45 AM
Revi
Revi's Avatar
I believe Lectric Limited makes/sells them. Not sure if the other Vette vendors are selling another version or just selling Letric Limiteds product.
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Lectric-Limited make excellent reproduction harness.
Old 09-29-2016, 10:28 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi John,
I agree that Lectric-Limited is a good choice.
The engine harness is pretty straight forward to do because it's quite simple and the access is good. Be sure to note the position of the wiper/washer connections and the wiring for the TCS connections.
The dash harness is a much more complicated harness and the necessary access is only gained by taking apart the dash panel and also the shifter and e-brake consoles.
I'd label the old dash harness connections while you're taking it out so you have something to refer to as you're putting the new one in place.
Good Luck!
Regards,
Alan
Old 09-29-2016, 02:02 PM
Tampa Jerry
Tampa Jerry's Avatar
Received 1,328 Likes on 960 Posts
Default Wiring harness
. The engine is a piece of cake to do. The dash, not so easy. Also, M&H also makes a great harness. Good luck. Jerry
Old 09-29-2016, 04:04 PM
Solid LT1
Solid LT1's Avatar
Letric Limited sourced through forum vendor Wilcox.....better pricing that establishing a dealer account with LL.....LL harnesses tend to look closer to original than the M&H's I looked at years ago, maybe things have changed....this was several years back.
To Looking to replace wiring harnesses on a 72 any sugggestions?
Quick Reply: Looking to replace wiring harnesses on a 72 any sugggestions?
