Upgraded to EFI
Upgraded to EFI
One of the upgrade for my 72 LT1 is EFI, and thinking of the Vorla system. Has anyone install this system and how to you like it, is it worth the money, is there something better for less?
Never heard of vorla. Are there enough people running it to where you can get support? IME that is the single most important thing, enough cars using it so there are people who have run into the same issues you will and have solved them.
Holley HP/Terminator
Fitech
Megasquirt
Those are the ones I see the most on the net. BTW, I'm running the Holley HP and it's a good system.
Fitech
Megasquirt
I am assuming that the OP is talking about Borla. Probably the 8 stack system. More info needed though.
For the OP, what kind of system are you thinking of? Throttle body injection, sequential multiport injection. I would stick to one of the established names like Zwede mentioned. I have a custom EFI setup using a FAST XFI 2.0 ECU. Works pretty well and was what the intake builder recommended. The HP would also have been a good choice as well.
I am local to you so if interested, let me know and I can show you how the FAST works with the laptop tuning.
newbie2vette (10-06-2016)
I went DPFI batch fire, speed density, so no MAF sensor back in '95 when I bought the car.....same 1227730 computer as used in '89+ F body and 91? vettes......
at first it was a L98 induction, but as time went on it's a highly modified LT1 induction with HEI in back where GOD intended.......
pump in back using stock 3/8 supply and the smaller 5/16 return lines, just top of the line hose and GOOD clamps on the steel lines.....
ALL of which should be common enough with a ~100 buck aftermarket chip....to get the price down to less than a grand for an L98 setup, which bought me some almost doubling of fuel economy over that old stock QJ ....I drove it with the OEM muncie 4 speed to Florida and back preparing to move....and up/down I 95 being pushed as the slow guy at 80 mph....with no overdrive the car got 24 mpg.....
since the overdrive automatic is installed, I have not done any trans/con driving at 80 mpg which is now only 2400 rpm instead of 4 grand or so......
ALL of these sort of mods depend on your use of the car.....
and the cost of the mods.....I had a run in with some aftermarket FI setups and it was a time waster.....went back to a well done chip in a stock computer and had done with it, just like the first time around.....
You say local, what area are you from southern MD?
I am just across the bridge in Lusby.
From what I can tell, the Borla 8-stack is a rather pricey EFI intake manifold. You still have to add the EFI computer and wiring and fuel system. They will quote a price on a FAST computer but you can use whichever standalone computer you want. So, use the manifold and add one of the popular EFI computers and you'll have a really cool looking system that should work well.
As for better for less, likely almost every other system could meet that requirement since the Borla manifold is around $4k and the rest of the parts needed will add at least another $1k to the installation. But, no other intake would look as cool.
