ground locations
Received 2,878 Likes
Hi H,
NO information in your profile!
It varies to some degree from year to year.
It's often on the driver's side frame rail.
For 71 it's on the same bolt as the antennas ground strap. Note 2 star washers are used.
Regards,
Alan
Regards,
Alan
Alan you really should start a pictorial book on the C3 !https://www.corvetteforum.com/forums...s/biggrin5.gif
Knowing your year model means EVERYTHING.
Often times...depending on the year model...it has nothing to do with the ground wire attached to the frame...but rather the ground wire in the light socket itself.
DUB
DUB
