Brake leaking
Brake leaking
78, Went to drive to the place I store the car for the winter and noticed a wet spot on the garage floor in a rather odd spot. Directly under the frame on the drivers side. reached up under and felt around. Is wet at the switch assembly. Not sure I am using the correct term, but in the AMI it says switch assembly. Got under the car and it looks like the line is leaking, might be a hair crack. This most likely happen when I removed the bolts securing the assembly when I was working on some other stuff. The AMI is calling this line "PIPE ASM-RR BRK FRT". It is item 11, PN 351580. Questions:
- What does rr brk frt mean?
- When I remove this line, I can see the lane goes all the way to the back than up, I assume once the rear is up in the air I will be able to access the that end of the line to remove it?
- Since this is the brake, I have no issue spending a little more $. Can you recommend a vendor which I will not get junk from for the line?
- While I am at it should I replace the switch assembly?
- Last, any advice is welcome.
