'79 tilt tele steering column, how do I remove the turn signal lever?
I have had to pull apart my column to replace the key switch, so thought while I'm at it I will give the column a paint, but how do you remove the lever? I read Jim Sheas paper but still not 100% on this.
Others will correct me if I'm wrong as it's been at least 9 years since I replaced mine. I'm pretty sure it just pulls out. I remember thinking it took significant force, and I thought I was going to break something, but it finally pulled out, and the replacement just popped in as I recall. Mine is a 79 tilt/tele without cruise.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The 79 lever is a press fit lever and pulls out.. just be careful when you do, the housing it is pressed into (the dimmer switch pivot) is something that can't be replaced.
Willcox
Willcox
Former Vendor
I would bet that your column is not correctly clocked.
DUB
could be, I cant push the level down far enough to actuate the cam to turn on the signal or make it to the lock position.
I looked at the Shea papers detailing how to get at it - and decided I could live with it!
If it works in either direction...I would bet your column and parts are not correctly keyed and centered so the turn signals are in a neutral state so they can be applied when the steering wheel is straight.
DUB
FWIW, on my 79, mine won't stay locked on for left turns either. No problem with right turns. And as mentioned above, I can hold the lever down and it operates normally. I've disassembled the column several times and gotten it to work for few months at a time, but it always gets out of adjustment again. I've never had the motivation to replace the turn signal switch to see if it permanently fixes the problem.
Turn your steering wheel slightly to one side and try it and see if it works. then if it does not...turn it back and go past 'centered' and go the other way a little bit and try it again.
DUB
DUB
I also need to know if the 'U' clip can be installed by it coming in from the top.
And if your wheels are STRAIGHT when you take the photo of the end of the column shaft.
NOW...if you want to start your own thread....PM me withe the link to it.
DUB
1) The turn signals STILL only cancel when they want to with right turns (usually) the worst.
2) I reaffirmed that if, despite patience, general skills and research, I am having a vexing problem there's an awfully good chance that the "experts" will encounter the same.
Need a photo of your column at this point.
DUB
DUB
KacyC3.
IF your front wheels are pointing straight....and this is your column. I see the problem right off the bat.
I can not clearly see the notch a the very end of your steering column shaft....but what I can see is that the columns is so badly rotated...the turn signals will never work correctly.
What appears to be a notch looks like it is point towards 10 o'clock which tells me someone had been down in this column rather deeply and got a part out 180 degrees.
The roughly 3/8" hole in the lock plate...that is opposite of the small oval area where the horn contact shows. The 3/8" hole needs to be a 6 o'clock...and the small oval white portion of the horn contact MUST be at 12 o'clock. AND the wheels MUST be pointing straight ahead.
DUB
DUB
I feel for ya! The key cylinder in my '79 locked in the "RUN" position. Merely moving the turn signal switch out of the way found some ball bearings of unknown origin. Put it all back together to find no cancels. Bought a switch from AutoZone and it refused to cancel after numerous attempts to get everything right. Bought an OEM switch and cancelling cam and had them installed by a local shop that specializes in Corvettes in a rare instance of giving up. Results:
Unless I am lucky as heck..I have YET to not be able to get turn signals to work correctly.
If you care to..and get back into this an post photos....I would like to help you because if we cannot get this...this would be the very first steering column I could not get the turn signals to work correctly.
DUB
KacyC3.
DUB
DUB
