rear spindle grease question
First, I have all the special tools and know how to do spindle bearings.
But I have a question:
I am following this: http://www.duntovmotors.com/tech-rear-spindle.php
It says to completely fill the bearing housing with grease.
I searched and read on other posts that people who filled it full, when the grease heated up, it expanded and leaked out onto the parking brake etc.
Do you fill them completely full of grease or no?
I don't fill them full. I pack the bearings and smear a little grease on the center of the housing. The grease that's not in the bearings will probably never flow into them anyway, plus the expansion and leakage problem you mentioned.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Classic case of someone that's probably never done one, reading something somewhere else and publishing it as gospel. BUNK...
Pack the bearings (we don't use packers either, we hand pack every bearing), put some ample grease in "the area" and assemble. I'm too old school for bearing packers, put the grease in your palm and pack it the old school way, when done you'll know the bearing has plenty of grease.
If you are setting up the clearance, do it dry.. Make sure you back set the bearings by rotating the set up tool and pulling outwards before popping it for clearance.
-Willcox
That may be the best write up Ive seen. Very simple and straight forward. BUT....I have one question. The link was for someone using NEW spindles. How much different is it if you plan to re use your old spindles?
Former Vendor
"It says to completely fill the bearing housing with grease. I searched and read on other posts that people who filled it full, when the grease heated up, it expanded and leaked out onto the parking brake etc."
I don't consider this to be an accurate post and just as I stated above, it was probably copied from some poste by someone that has never done this job... It's just my feeling because the statement is not correct and I'm no picking on them by any means.
The procedure is the same for new as with old.... Back set the bearing clearance dry... Once you know the desired shim required, grease the bearings and put it back together. I like to run out to be between 3 and 4 thousandths and I have the luxury of having a lathe so that I can trim the spacer so that I can obtain that clearance on every job. I've been doing this for over thirty years and to date I've never had one bearing failure under warranty.
Never fill the housing full of grease.. grease will skreet as it ages, and if you pack the housing full it will leak out of the outer seal.
Willcox
Rcdizy (10-25-2016)
Based on the statement
The procedure is the same for new as with old.... Back set the bearing clearance dry... Once you know the desired shim required, grease the bearings and put it back together. I like to run out to be between 3 and 4 thousandths and I have the luxury of having a lathe so that I can trim the spacer so that I can obtain that clearance on every job. I've been doing this since 1973 and to date I've never had one bearing failure under warranty.
Willcox
Willcox
I also have a lathe and can make it whatever is best.
i had both sides 1 thou end play with setup tool, waiting to proceed in next day or so
so, having all the time in the world, knowledge, spacers, shims, and a lathe, to get the clearance to whatever exact number i want within spec... .003 is best? I thought spec was between .001-,008 tighter end being better.
When i removed the old bearings they were between .008, .010 and the wheels felt very loose.
Mike
The following 2 users liked this post by tracdogg2:
lionelhutz (11-26-2016),
Rcdizy (11-10-2016)
becauae of the warnings I got about .001.
seems really good.
I do not pack the spindle reservoir with grease. I only apply a film on the inside.
As for tend play...I set them at .001" to .003"...and I do not go any more than .003 EVER.
THEN I spend the time making sure that rotor is as true as possible.
I do all of this so the lipped sealed calipers that I use will last.
DUB
DUB
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
I found this thread to be VERY informative regarding grease. I just pulled my spindles yesterday for this job. Bubba was at it again...both spindles spun freely by hand before removal, BUT, the driver side had an audible grind noise and the pass. side seemed a little tight. When I removed driver side 2 of the outer bearings rollers came out in halves and it was dry as dust inside. The passenger side had LOTS of cooked, hard grease inside between the bearings but not much on the outer. As a side note, that side stunk worse than roadkill when I opened it up. I saw that both outer bearings and races were chewed up pretty good, but both of the inners were surprisingly AOK.
The reason for this mess? Neither side was set up properly for end-play clearance...neither side had any spacers. Spacer kits, bearings, races and seals are now on order.
Thanks Bubba!
Thanks Bubba!
Once you finally decide HOW to do this job, be sure to use a full-synthetic grease for packing the bearings. Synthetic lubes are so much better (in EVERY respect) to regular lubes, it just doesn't make any sense to use what Chevy recommended decades before synthetics became the "standard" of use. They don't "cake", they don't "separate", they don't "melt"; and they lubricate MUCH, MUCH better than regular grease.
You can't re-grease this area after-the-fact. Use the right stuff when you build them.
DUB
Former Vendor
Sure the spec is .001 - .008.. But I'll tell you I've been doing these a long time... I've never had one come back... I'm 0 for lifetime in failures so for me if 3-4 works I'm sticking with it.
Truly anything in the specified range will work but I tend to stick with what has worked for me.
IMHO,
Ernie
The following 2 users liked this post by Willcox Corvette:
Red86Z51 (11-26-2016)
Once set up correctly and greased properly, approximately how much time can I expect to pass before having to go in and re-grease the rears again?
Also, will there be that much of a difference in that elapsed time between servicing if I use synthetic vs. high temp/press. NGLI No. 2?
In my case, there will be no hard driving whatsoever. I'm older now and tend to drive with more of a helium foot...
That's the point; the rear T/A bearings are NOT servicible. Once you close them up, that's it until you replace the bearings again. Hence, the reason for switching to full-synthetic grease.
Yes, there are gizmos that are sold as ways to re-grease those bearings. But, they don't really work....no way to remove any 'old' grease. And, if you use full-synthetic, you don't NEED to service them.
I've seen those "greasers", but have read time and time again they only hit the inner bearing...waste of money IMO.
So is there a particular synthetic grease you would recommend?
AS for any difference in using synthetic grease versus regular grease...I never give it any thought because I have yet to have to tear into one of my rear wheel bearing jobs when I used conventional grease....and none yet with the synthetic grease I use.
I also strive to not get any more that .003" bearing play when I do them.
DUB
