Edelbrock rpm heads and weiand stealth intake manifold holes dont not line up
Edelbrock rpm heads and weiand stealth intake manifold holes do not line up
I have edelbrock rpm heads and a weiand stealth intake.
When I put on the intake the holes for the bolts do not line up. This sbc intake is the earlier idle-6800 rpm (the current version is idle-6400 rpm, not sure it that makes a difference) Has anyone experienced this issue?
Heads were probably milled, if the intake is not too far off you can elongate the holes on the intake
