My Street Fire distributor eats coils
Old 12-02-2016, 12:29 PM
Snoopysvet
Snoopysvet's Avatar
Default My Street Fire distributor eats coils
I purchased a MSD 8362 Street Fire distributor a few years ago. I have a 1978 Corvette that gets driven only a thousand miles per year. After a year the coil went bad. I purchased another Borg Warner coil that lasted only a year, now I am on my third coil.
What could be happening?
Old 12-02-2016, 12:33 PM
Jebbysan
Dr. Detroit
Support Corvetteforum!
Jebbysan's Avatar
Received 3,892 Likes on 2,564 Posts
Check to make sure there is no "overvoltage".....higher than say 14.5-15 v.....it is only a one wire plug in BUT.......how are your ground straps?
An HEI distributor is grounded by the block......
Jebby
Old 12-02-2016, 02:46 PM
cardo0
cardo0's Avatar
Location: Las Vegas - Just stop perpetuating myths please.
Try a good aftermarket performance coil like MSD or Accel. They are built to handle higher current loads. BTW how did you install your coil? Most auto coils are liquid filled and need to stay vertical - not horizontal or weird angles. Also high temp can kill a coil to. Some locations on the intake are much hotter than others.
Hope this can help.
Old 12-03-2016, 11:39 AM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
You have the wrong primary current. Check your ballast resistor.
Old 12-03-2016, 11:51 AM
Jebbysan
Dr. Detroit
Jebbysan's Avatar
No ballast resistor on a 78'.
Jebby
Old 12-03-2016, 11:57 AM
Big2Bird
Big2Bird's Avatar
Jebby
Your correct. 8362 is an HEI.
I would buy a DUI unit, and be done with it. I have little faith in most MSD stuff anymore.
To My Street Fire distributor eats coils
Quick Reply: My Street Fire distributor eats coils
