Chevy '68 Gen IV 427 Distributor in 454 Gen VI Engine
'68 Roaster, originally 427, now 454 Gen VI, with MSD ignition. In process of rewiring, spoke with Lectric Limited, they mentioned disconnecting MSD and using their ignition system below.
38131 BREAKERLESS-SE ELECTRONIC IGNITION CONVERSION, Converts any GM V8 engine (equipped with: points, point-adjustment window on distributor cap, screw-on type rotor, & original-type coil) to solid-state electronic ignition. TOTALLY STOCK APPEARANCE WITH DISTRIBUTOR CAP INSTALLED!!
So, was told to use '68 Distributor, And like the idea of using ignition conversion because it is a direct connect fit and with MSD, am cutting, splicing new harness.
Question... Has anyone else tried the LL conversion? Does a 427 Gen IV distributor work in a 454 Gen VI engine ok? Thought there was a distributor gear specific for the Gen VI blocks? Is there a 427 distributor better for this application? Thanks!
If so, what distributor would I look for?
If the distributor physically fits (and mates to the cam drive gear) and it is an 8 cyl. unit in an 8 cyl. engine, all should work OK. The firing order is determined by the sequence of plug wires as installed in the dist. cap.
Yes. The firing order is the same from a '65 on up to your '96 and beyond, until the 8.1L which changed firing order and distributor length too (the 8.1/496 is a tall deck block).
Any of the standard points distributors can be converted to breakerless. As to which one , that would be your preference.
Yes, if its a SBC/BBC Tach Drive it'll work. I wouldn't bother with Points, I have an older Mallory Unilite and a MSD Mag. pickup Tach drive, they both work great. I wouldn't hesitate to buy either one used, the bushing/bearing can be replaced if worn (as long as the housing isn't damaged). I have an original Points type Tach. drive dist. as well, I'd only use it for NCRS resto purposes tho (so I'm not using it )
