1978 Corvette engine bay relays location
1 have a 1978 Pace car and looking for some help, im looking for all the engine bay relays and where they are located in engine bay, any help would be much appreciated
how about looking at it another way, exactly which relay do you need the location of?
have you looked in the AIM, assembly instruction manual?
have you looked in the factory service manual?
The only relay I know of in the engine bay of a '78 is the high-speed blower relay. It is at the rear right.
Most relays are in the cabin:
the horn relay (above/left) the fuse box
the alarm relay in the center console just ahead of the shifter
the power antenna relay (if equipped) in the center console behind the emergency brake lever
