Flowmaster Force II Crossmember-back System for '70-'73 Corvette Stingray
Application:
Fits 1970-1973 Corvette Stingray with 454 Big Block Engine (Can also be used for High HP Small Block Applications).
Description:
Flowmaster's Force II Crossmember-back system for the 1970-1973 Corvette Stingray with 454 Big Block Engine is perfect for the person looking for a moderate exterior and mild interior exhaust tone, with all of the performance benefits that you would expect from Flowmaster. This bolt-on DOR (Dual Out the Rear) system for the 454ci V8 models (or high HP small blocks) features specially tuned stainless steel 50 Series Delta Flow mufflers, a Scavenger X-pipe assembly and 2.50” 409S stainless steel tailpipes. Like all Flowmaster® systems the pipes are all mandrel bent to reduce any restrictions and maximize performance. The system finishes with 2.50” polished 304S stainless steel tips that exit within the factory cutout bezels. The exhaust system is manufactured in the USA and is covered by Flowmaster’s Lifetime Limited Warranty. Designed for an easy fit, this system includes all necessary parts and hardware for installation.
- Stainless Steel Construction
- Dyno Tuned For Maximum Performance
- Patented Delta Flow Technology
- Lifetime Limited Warranty
Ryan Menzies (02-16-2017)
Hi,
We are 99% sure that our Force II Cat-back System (part# 817667) should work for your application. Due to not having an available '82 Corvette to verify fitment of this particular system on, we recommend reviewing the installation instructions to ensure that it should fit your particular car. If you have any additional questions, or would like a personalized product recommendation, give us a call at 707-544-4761.
Give us a call at 707-544-4761 and mention that you were referred by the forum, that way we can be sure to give you our best pricing on your purchase.
-Team Flowmaster
-Team Flowmaster
