True Dual Exhaust 1982 Crossfire
Piecing together dads former 1982 corvette in hopes of getting it running for summer. Just found (most) of the OEM exhaust setup. Originally planned to keep it OEM just how it was...cheap muffler should be easy to find. Or am I better off buying the true dual system and scrapping this.
Read Corvette America sold a kit - direct bolt on, no fab needed. Did not see on the site, or any similar kits that are direct fit from forum vendors - Is this the same one for around $550 on Ebay/Amazon?
if you are not wanting to spend much ,open up the cat buy new better flowing mufflers and put back on.there is a true dual system you can buy for off road use[lol] but you will have several hundred dollars in it.
I changed mine out to dual exhaust made by Corvette Central. Bolts right up, sounds great. I got it from Corvette Pacifica as they were cheaper. I also bumped up the initial timing 3 degrees and changed the chip. Much better performance with not much money spent.
Received 1,469 Likes
Cruise-In II Veteran
Do you have to pass emissions testing in your state?
Will CrossFire ECM work properly with no CAT in the system??? You need the O2 sensor to manage the fuel mixture; but without the CAT it will be throwing codes and forcing ECM to run in default mode.
No emissions testing here in Florida. I have a true dual exhaust system with a 'H' crossover pipe and NO catalytic converter on my 78 Pace Car. It looks and sounds good.
And1bbaii7 (02-19-2017)
No emissions in FL!
I used this crossmember on my new custom exhaust. It says 68-81 C3s, but it fits just fine if you don't need a CAT on an 82. I did a custom all SS system. I have pics here somewhere and will post up if I find them.
https://www.transmissioncenter.com/s...transmissions/
Your ECM will work fine without a CAT as well. I used to run Flow Pro mufflers, but switched to Hooker Max Flows when I did the new exhaust.
Also, instead of installing a "H" pipe, I would opt for a "X" pipe crossover instead. The choice is yours. Ensure that you reinstall your O2 sensor in the header collector if that's what your plan on running and make sure the bung is more towards the top on an angle. You don't want it low or on the bottom due to water contamination.
Found a couple of pics. hope this helps.
That looks great Buc!
What did it all run you? I'm wondering if it ends up being less expensive to just have a shop weld up the pipes custom after you add in shipping for a complete setup ordered online? You are sure of it all fitting by having it put together at a shop as well.
BTW then I registered my 80 in Hillsborough County FL this past year they didn't even do a visual inspection, just wanted to see a VIN on the car.
Maybe that's why my '79 L82 literally rattles the walls when idling in the garage. While I rarely go there the owner of the local Corvette shop (it's slightly out-of-town) does though say, "I love that sound and always know when you're coming."
