1st post: oil pressure pinned @80
Hi all, I'm AL, just bought a 75 vette, 350, auto, oil pressure pinned @80 with vehicle on or off, no reading amp or temp, horn doesn't work, interior lights work when open the pass side only, radio works, clock doesn't work,runs great, no smoke, any ideas? TIA
Start with the fuses under the dash, drivers side.
bluenight44 (02-25-2017)
I believe there's an issue at times with the ground on back of instrument cluster at console...specifically the ground on the amp meter..I think. The interior light issue is likely unrelated and tied to the switch at the door jamb.
Here, courtesy of Forum sponsor vendor Willcox Corvette https://willcoxcorvette.com/
For the oil pressure I'd start with the single wire coming from the sensor; mine was barely hanging on which also resulted in an continuous 80 PSI reading.
Re-soldering the wire fixed it. Getting the clip out of it's rubber housing was a bit of a fiddle.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Pull the wire off the sender and ground it out.. the oil pressure gauge should go to 0... If it fails this test then I'd look at the gauge as being the issue.
the oil pressure gauge on your car is exactly the same gauge as a fuel gauge with the exception of the dampening fluid. Both work on the same scale 0 - 90 ohms with the only difference being the dampening fluid inside the gauge. The fluid in a oil pressure gauge is thinner than that of a fuel gauge which allows for a faster response time.
So use this chart and just pretend the gauge say's oil pressure instead of fuel... (until I can make a new one for oil pressure gauges).
Willcox
worship79 (04-29-2017)
