Flowmaster Force II Crossmember-back System for '74-'79 Corvette
Application:
Fits 1974-1979 Chevrolet Corvette with 350 Cubic inch engine. (Not Emissions Legal for 1975-1979 Vehicles).
Description:
Flowmaster's Force II Crossmember-back system for the 1974-1979 Chevrolet Corvette is perfect for the person looking for a moderate exterior and mild interior exhaust tone, with all of the performance benefits that you would expect from Flowmaster. This bolt-on DOR (Dual Out the Rear) system for the 5.7L V8 features specially tuned stainless steel 60 Series Delta Flow mufflers, a Scavenger X-pipe assembly and 2.25" 409S stainless steel tailpipes. Like all Flowmaster® systems, the pipes are all mandrel bent to reduce any restrictions and maximize performance. The system finishes with 3.00" polished 304S stainless steel tips. The exhaust system is manufactured in the USA and is covered by Flowmaster's Lifetime Limited Warranty. Designed for an easy fit, this system includes all necessary parts and hardware for installation. Note: Intended for Off Road Use Only on 1975-1979 Models.
- Stainless Steel Construction
- Dyno Tuned For Maximum Performance
- Patented Delta Flow Technology
- Lifetime Limited Warranty
Location: Las Vegas - Just stop perpetuating myths please.
Nice! A dedicated exh sys w/crossover is something we needed. 3" pipes should easily support big block power.
I like it!
Ooops. Well 2.25 " should work well enough.
I like it!
Keep in mind, guys, that 2.25" MANDREL BENT tubing will outflow 2.5" compression bent tubing.....
