81 Headlight upgrade LED
Old 02-22-2017, 06:48 PM
spedaleden
spedaleden's Avatar
Default 81 Headlight upgrade LED
I did a post a while back but pic of the headlamps was in the garage. here is a pic outside. Bright lights are off.
Old 02-22-2017, 09:48 PM
Engage
Engage's Avatar
How hard was it to change over?
Old 02-22-2017, 11:49 PM
vetteguy75
Support Corvetteforum!
vetteguy75's Avatar
LA Events Coordinator
Old 02-24-2017, 05:37 PM
spedaleden
spedaleden's Avatar
Pretty easy. Use factory wiring but you have to cut the buckets and headlamp housings
You need to cut the bucket on the inner circle and cut out the aluminum with a hole saw. It was easy to do.
LEDS http://www.vleds.com/shop-bulb-numbe.../9006-lmz.html
Headlamps high and low beams (Projectors) https://www.dapperlighting.com/colle...nt=25176242056
These have a halo but I did not hook up the halo feature
If you ever had a issue on a trip, you can plug in a factory seal beam if you wanted
The following 2 users liked this post by spedaleden:
Engage (02-24-2017), ratflinger (02-24-2017)
Old 02-24-2017, 11:14 PM
ratflinger
NCM Grand Opening Veteran
ratflinger's Avatar
St. Jude Donor '11, '17
Expensive but impressive - thanks
Old 02-25-2017, 07:44 PM
SwampeastMike
SwampeastMike's Avatar
They do look nice even if the HALO feature is a complete waste as DRLs when you have pop-up headlights.
Have you enlisted a helper to see them as an oncoming car on a dark highway? My #1 problem with aftermarket HID/LED headlamps is their tendency to blind oncoming drivers and I refuse to use them for that very reason.
Old 02-27-2017, 11:25 AM
spedaleden
spedaleden's Avatar
My son has driven in front of me and drove in opposite direction and said it bright but does not blind you. I have never gotten flashing brights from others when driving
SwampeastMike (02-27-2017)
Old 02-27-2017, 12:22 PM
SwampeastMike
Thanks for the very useful reply!
To 81 Headlight upgrade LED
Quick Reply: 81 Headlight upgrade LED
