383 spark plug recommendations
Hi,I bought a 1979 with a 383 Stroker. Runs great, but pings. We tried retarding the timing a bit, but it still pings. It has cast heads and, according to the rebuilder, has 9:1 compression. I haven't pulled a plug yet, but thought I would check and see what plug would be good for this. R44?
I doubt that you have a 9 cr 383 because it would need custom deep dish pistons required. The fix is a bigger duration cam
Spark plugs....
When it comes to the spark plugs and the pinging it should not cause it unless you are way off on the heat range. As to what type of plugs in accordance to heat range that your engine likes the best i go by what David Vizard says in his holley super tune book. "the spark plug should run at a temperature to ensure deposit burn off and no hotter"
Received 3,043 Likes
St. Jude Donor '05
When you pull a plug if you look at the strap on the outside you may see what looks like a light stripe if you get a chance post a pic. Tells a little about timing. If its 9:1 even 9.5 bet you can tune it out.
No amount of timing retard can fix a small cam and stock heads. I've seen this over and over with people doing budget 383s
If you have 9 to 1 R44 or 45 plugs will be fine
Get a dial type timing light and see what the timing is at 3500 rpm with the vacuum advanced off
Because of the many types of heads, some take short reach, but some take a longer reach spark plug. Before buying, ensure a couple of things:
1. Does it have a flat seat or tapered seat?
2. Measure the depth of threads in the spark plug hole. Some old stock heads have only 3/8" of threads; some later stock heads have tapered seats needing a 1/2" reach plug; most aluminum and some aftermarket cast iron heads need a 3/4" reach.
Make sure to get this right because if you use a short thread plug in a long thread hole, it won't run very well.
