Motor Mount replacement
1st Gear
This is my first Corvette. I have a 1977 Corvette and I may need to replace the Motor Mounts. Can I replace them without removing the Engine.
Received 19,299 Likes
'20-'21-'22-'23-'24
Moved this to C3 Tech.
Received 2,878 Likes
Primoz (07-17-2021)
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
Yes, as Alan says. Be careful how much you jack the engine. Your dist'r could hit the firewall, fan hit the shroud, etc. Place a piece of 2X4 across the bottom of the oil pan and jack the engine to required height and then support the engine with a jack stand. Also, use jack stands to support the car.
