Wiper door canister?
Trying to troubleshoot some issues while away from the car. Should the front nipple hold a vacuum, or can it bleed down with no adverse effect. Currently when the car is started the door will open. I can close it with a handheld vacuum pump, but it doesn't hold vacuum. If it should hold is that something the rear pylon looking thing or the front plug will help?
My current canister also the front nipple make a 90 deg bend, while replacements are straight. Some used one I've found say they were off 1970 with straight nipple. Is the straight fitting a later design or where interchangeable during 1970 model year. I'm trying to do a correct driver, otherwise would not care,
Dementer sole survivor
Received 6,260 Likes
2016 C3 of Year Finalist
Do they sell repair kits for canisters and how do they come apart. I have new looking one with a bent rod
Received 2,878 Likes
Hi,
Bob Demmel in Texas rebuilds and restores wiper door and headlight door actuators.
He is able to replace the seal on the inner disc (don't know what it's called) too. (Un-crimp.)
He can do just a functional rebuild, just a cosmetic re-plate, or both.
His work is thought of pretty highly.
Regards,
Alan
Regards,
Alan
Rescue Rogers (03-23-2017)
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
70-71 wiper actuators looked like this.
https://willcoxcorvette.com/corvette...actuator-70-71
Use the following to test and/or repair.
Former Vendor
https://willcoxcorvette.com/corvette...actuator-71-72
My canister is holding vacuum on both sides now. Trimmed the hose on the front and seems good. Also found that one of override switches had the vacuum lines disconnected. Didn't fire it up to see if the door operates yet.
