Anybody Have Ideas?
Old 03-26-2017, 04:30 PM
sunflower 1972
sunflower 1972's Avatar
Default Anybody Have Ideas?
Just finished my winter project today (Edelbrock E-Street Cylinder Heads). Just finished timing the engine and I discovered a minor issue with distributor vacuum canister and the right hand ignition shield bracket. Only thing I can come up with is buying a new bracket and drilling a hole or reclock the distributor. I'd rather not reclock the distributor if I can do something else. Anyone have any ideas?
Old 03-26-2017, 04:34 PM
gjohnson
gjohnson's Avatar
Looks to me like you could grind off the lip of the bracket so you have a straight shot on the hose
Old 03-26-2017, 04:51 PM
BKbroiler
BKbroiler's Avatar
Pull the distributor up, move the gear 1 tooth and reset your timing.
Old 03-26-2017, 05:15 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi s,
I believe typically the distributor is clocked so the advance can and it's vacuum hose come around the rear of the bracket for the shielding.
Regards,
Alan
Old 03-26-2017, 05:19 PM
Tooch1
Tooch1's Avatar
Hey Sunflower,
To me it doesn't look like you have the correct right side shield bracket. Even though I have a 73' I'm pretty sure the 72' bracket was the same. It's curved to let the vacuum hose clear. Is that an edelbrock intake?
Just a thought. Here's a pic of mine?
Tooch
Old 03-26-2017, 05:24 PM
Alan 71
Alan 71's Avatar
Hi Tooch,
I agree that the bracket is typically mounted under the second from the rear manifold bolt?….look closely at s's photo.
Regards,
Alan
Old 03-26-2017, 05:28 PM
Tooch1
Tooch1's Avatar
Originally Posted by Alan 71
Hi Tooch,
Regards,
Alan
Oops!
Yes, I see it now. He's using the correct bolt. Maybe the bracket change will work for him. Made the correction above.....I'm slipping Alan
Old 03-26-2017, 05:39 PM
Alan 71
Alan 71's Avatar
Hi Tooch,
I hope s turns the distributor.
There's no real reason to cut the bracket.
Regards,
Alan
It'll be a little easier to set the dwell too.
Old 03-26-2017, 05:45 PM
Tooch1
Tooch1's Avatar
Hi Tooch,
Regards,
Alan
Me too Alan,
His is facing more forward than ours, using the end of the valve cover as a guide..
I just sent you a PM!
Tooch
Old 03-26-2017, 06:57 PM
sunflower 1972
I'm having a fart here. Won't that knock the distributor rotor off of the #1 tower of the distributor cap? Could you please explain in a little more detail?
Old 03-26-2017, 07:14 PM
68notray
68notray's Avatar
No, of course not. Lifting the dizzy to re clock it 1 or 2 teeth doesn't change anything, just have to re set the timing. Keep in mind the oil shaft WILL NOT BE LINED UP so it won't drop back in. Stick a long screwdriver down there and move the shaft a little.
Old 03-26-2017, 07:47 PM
sunflower 1972
Thanks for all the replies, gentlemen. I appreciate it.
Old 03-26-2017, 09:18 PM
BLUE1972
BLUE1972's Avatar
Received 1,122 Likes on 732 Posts
Loosen the distributor, turn it one plug wire plug length clockwise, move the wires 1 plug to the right.
Done..
Old 03-27-2017, 09:34 AM
sunflower 1972
Done..
I just had a lightbulb moment. So, if I move all the wires at the distributor cap 1 tower counter clockwise, mark the side of the distributor housing with the new location of #1 tower, pull dizzy and turn rotor 1 or 2 teeth clockwise, drop the dizzy so rotor lines up with the new #1 tower, I should be good to go. Correct?
Old 03-27-2017, 11:33 AM
69FASTFUN
69FASTFUN's Avatar
I am wondering what the tach cable looks like is it in a sharp angle. He may have to reclock the distributor so the tach cable is not in a bind and that may solve the vacuum line.
Old 03-27-2017, 11:58 AM
sunflower 1972
Tach cable right now is good. Has a nice smooth very gradual bend to it.
Old 03-27-2017, 09:39 PM
BLUE1972
BLUE1972's Avatar
NO - you don't have to pull the distributor, just turn / move it 1 plug wire clockwise and move the wires I wire counterclockwise. The rotor will be on the same wire as before the move.
Doesn't matter where the rotor actually is... for illustration..
looking at a clock - if the rotor pointed to 6 oclock, rotate the distributor so 6 goes to 7's (o'clock) position. now move the wire at # 7 position to #6 and the rotor still points to #6. follow all the way around wire by wire and you are good to go. #8 (o'clock) wire position to #7 (o'clock) ..... last will be 6 to 5.
To Anybody Have Ideas?
Old 03-27-2017, 10:08 PM
blk79nj
blk79nj's Avatar
sunflower 1972 (04-08-2017)
Old 03-28-2017, 06:06 PM
Metalhead140
Metalhead140's Avatar
C3 of Year Finalist (track prepared) 2019
2nd this.
Old 03-30-2017, 12:19 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
the right way would be pull dist. advance 1 tooth and retime.
the easy way, leave dist. seated then rotate all plug wires, 1 plug over.
loosen dist. and rotate 1 plug over.
con's : your plug wires will not be in the expected place for next mechanic.
Pro : easy way you do not have to pull the Dist.
Quick Reply: Anybody Have Ideas?
