A/C o-rings
Old 03-28-2017, 08:09 AM
See Three
See Three's Avatar
Default A/C o-rings
I have a couple of A/C hoses from a 71 LS-5 that are going to be cleaned up and re-used. I can take them to an o-ring supplier and have him match up the seals that are on each end but are there any documents that tell you the o-ring numbers (not GM numbers)? Also, one hose has some black paint overspray on it. What chemicals are safe to remove paint from rubber?
Old 03-28-2017, 08:20 AM
leadfoot4
leadfoot4's Avatar
Received 1,339 Likes on 1,092 Posts
It might be easier if you go to Advance Auto parts or Autozone, and purchase a/c specific rings....
Old 03-28-2017, 09:39 AM
71 Green 454
71 Green 454's Avatar
Received 1,186 Likes on 650 Posts
I can tell you 2 NAPA part numbers:
Compressor hose block connection, NAPA part # 407122.
Smaller ones at drier, NAPA part # 407006.
See Three (03-29-2017)
Old 03-28-2017, 10:29 AM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
Yup. They have an assortment for about $5. The thinner ones are usually correct.
Old 03-28-2017, 12:09 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
you want the green orings, not black.
Old 03-28-2017, 12:33 PM
See Three
See Three's Avatar
Green is usually Viton where chemical resistance is needed, are there kits available with green or are you talking about getting them sized at a supplier? The ones that are in it are black I think (buna nitrile).
Edit: Just read that Viton is brown and not compatible, but green is Hydrogenated NBR and is a step up from the standard NBR. Good to know.
Old 03-28-2017, 03:20 PM
69Vett
69Vett's Avatar
they use the green with the newer freon gases, the gases are a smaller atom size and can leak thru the black orings, standard green on newer A/C systems.
which is good for all types of Freon.
To A/C o-rings
Quick Reply: A/C o-rings
