Gauge Repairs
Cruising
Gauge Repairs
Fellows, doing a complete restoration on a 69 corvette and I'm looking for a recommendation on where to send the instrument cluster for inspection/repair, thanks.
Look at Corvette Central on line in the gauges section and you will see they advertise for restoration of the stock gauges, tachometer and speedometer. The prices seem reasonable. I haven't used this service. I just purchased all new.
Received 2,878 Likes
Hi 70,
You might want to check into D&M Restorations in Greenville, South Carolina.
They repaired the tachometer from my 71 and I was pleased with it.
Regards,
Alan
Regards,
Alan
Received 3,218 Likes
I used Roger at Corvette Instrument Services.
Redid my gauges and also does custom work. Had a Oil temp gauge with correct green lettering to replace my clock and a voltmeter to replace the ammeter.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you are just wanting the gauges tested you can do this yourself. On my site I've got multiple test and help pages. (link posted below). If you need a ohms input you can use a flasher which normally has around 50 ohms input and will assist you in testing or you can purchase an adjustable POT online. Testing the gauges is not really all that hard and if you do try this you can always email me at service@Willcoxcorvette.com if you get confused on something.
http://repairs.willcoxcorvette.com/?yt=1969&s=gauge
Willcox
Willcox
Anyone using Corvette Specialities of Maryland West?? I know they do very nice work on C2 stuff. I dunno about C3.
Larry
Larry
I've also used D&M of Greenville, South Carolina and they do outstanding work as well.
Both of them are at Corvettes at Carlisle.
Good luck... GUSTO
ttt. Helping a friend.
Larry
Larry
