Tip of the Day-Th350 Shifter Shaft Seal
You can replace the shifter shaft seal ad nauseum if you have a leak. Been there and done it three times. The real problem could be the shifter shaft! The seal can actually score the metal shaft and no re-newing of the seal will make it fluid tight. Does sound a little bizarre that a rubber seal could inflict such damage but apparently so. So replace the shaft. And here is the part number. My tip of today....
[Modified by paul79, 6:46 PM 9/25/2002]
Re: Tip of the Day-Th350 Shifter Shaft Seal (silver 80)
Well look it's made in Canada, no wonder it's so soft :lol: :lol:
With the cross border insults aside Thanks for the tip Paul
Scott
Scott
Re: Tip of the Day-Th350 Shifter Shaft Seal (Scott78)
Scott,
I never thought of that! And some talented person with a sense of humour can answer the question: What do you get when you put together a Canadian-made TH350 shifter shaft with a USA seal? I think I better move this to Off Topic. Or post a pic of my cat ;) .
Re: Tip of the Day-Th350 Shifter Shaft Seal (paul79)
I agree with you Paul. I just did this job and did notice some wear, but since I did not have the part handy I reinstalled the shaft. So far, no leaks.
